CUCM 8.5 and CME 7.0
Hi there,
This is my question, it might not make much sense, but I'm asking anyway..
I have 2801 running CME 7.0 it works well so far been running for about a month, with all inbound outbound calls work flawless, knock on wood ..
The router is also used as a WAN router which is connect directly to ISP's Internet and SIP carrier ..
I have added a Unity and CUCM 8.5 on a server connected on the same LAN, i configured a DP for the CUCM 8.5 on the router and was able to register Cisco IP Communicator and and successfully dial out, however I couldn't get inbound calls..
I did create a DP with the full DP as destination pattern, but the call didn't get to the CUCM 8.5, it simply failed.
Also i have a SIP trunk on the CUCM 8.5 to the CUBE and appropriate DP..
My question would be is it possible to run a CME 7.0 and CUCM 8.5 at the same time using the same router/CUBE ?
Thanks for reading and even better replying .
Hall of Fame Super Silver
Sure.
Please post your configuration along with "debug ccsip messages", "debug voice dialpeer" and what number you dialed.
Chris
Re: CUCM 8.5 and CME 7.0
Hey Cris,
I have attached the logg file with the debugs..
Thje CM local ip is 172.22.100.200 and DP is 8, number called is three473124343
364
