Community Member
CUCM 8.5 - C2901 MTP - BANDWIDTH ISSUE
Hello.
We are running a CUCM 8.5 cluster and we have a Cisco 2901.
The 2901 is our MTP, CFB and CUBE.
We have two interfaces Gigabit in that 2901, one interface see to the PSTN WAN and the otherone to the LAN IP Phones.
Whenever we put an inbound or outbound PSTN call, in the CUBE/MTP that call using 138 kbps (average) only for incoming traffic in both interface, but in the interfaces's switch directly connected to that 2901 only we see 85 kbps (average) in the outbound traffic.
Why the MTP generate more incomming traffic like if the C2901 re-process the RTP to use MTP,...but I don´t know that is normal or no ?
We use Software MTP G711a.
We have the same Media Resource Group for both (IP Phones and SIP Trunk)
We have check the MTP checkbox on the SIP Trunk page.
We have all regions with G711
We attach you the configuration in the CUBE.
We attach the topology in PPT file.
My version in my 2901 is: Version 15.1(4)M2
My MRGL have
MRG_PUBLIC_PUBLISHER
MRG_MTY1
My MRG have
               ANN_CUCM851
MOH_CUCM851
MRG_MTY1
CNF2921NAU
MTPG711aNAU
MRG_CUARENTENA
CFB_CUCM851
CFB_CUCM852
MTP_CUCM851
MTP_CUCM852
MTPG729nau
Add the evidence in
CUBE_GOLD#sh int gig0/0 | inc 30  sec
  30 second input rate 137000 bits/sec, 100  packets/sec
  30 second output rate 86000 bits/sec, 50  packets/sec
CUBE_GOLD#
CUBE_GOLD#
CUBE_GOLD#sh int gig0/1 | inc 30  sec
  30 second input rate 138000 bits/sec, 102  packets/sec
  30 second output rate 88000 bits/sec, 51  packets/sec
CUBE_GOLD#
SW_ISOL_7.01#sh int fas0/17 | inc 30  sec
  30 second input rate 88000 bits/sec, 51  packets/sec
  30 second output rate 87000 bits/sec, 51  packets/sec
SW_ISOL_7.01#sh int fas0/18 | inc 30  sec
  30 second input rate 89000 bits/sec, 50  packets/sec
  30 second output rate 90000 bits/sec, 52  packets/sec
SW_ISOL_7.01#
SW_GOLD_MTY#sh int gig0/13 | inc 30  sec
  30 second output rate 90000 bits/sec, 51  packets/sec
SW_GOLD_MTY#
SW_GOLD_MTY#
CUBE_GOLD#show dspfarm dsp all
SLOT DSP VERSION  STATUS CHNL USE   TYPE     RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   28.3.2   UP     N/A  FREE  conf     2      -         -         -
Total number of DSPFARM DSP channel(s)  1
CUBE_GOLD#sh sccp call-identifications
sess_id    callref    conn_id    conn_id_tx  spid       rtp_callid msp_callid bridge_id  codec   stype prof_id
16777245   -          16777271   0           16777216   18569      18570      60         g711a   mtp   4
16777245   -          16777270   0           16777216   18566      18570      59         g711a   mtp   4
Total number of active session(s) 1
CUBE_GOLD#
CUBE_GOLD#sh call  act
CUBE_GOLD#sh call active voice  brief
<ID>: <CallID>  <start>.<index> +<connect> pid:<peer_id> <dir>  <addr> <state>
  dur hh:mm:ss  tx:<packets>/<bytes>  rx:<packets>/<bytes>
IP <ip>:<udp>  rtt:<time>ms pl:<play>/<gap>ms  lost:<lost>/<early>/<late>
   delay:<last>/<min>/<max>ms  <codec>
media inactive detected:<y/n> media  cntrl rcvd:<y/n> timestamp:<time>
long duration call detected:<y/n>  long duration call duration :<sec>  timestamp:<time>
  MODEMPASS <method>  buf:<fills>/<drains> loss <overall%>  <multipkt>/<corrected>
   last <buf event time>s  dur:<Min>/<Max>s
FR <protocol> [int dlci cid]  vad:<y/n> dtmf:<y/n> seq:<y/n>
  <codec> (payload  size)
ATM <protocol> [int vpi/vci cid]  vad:<y/n> dtmf:<y/n> seq:<y/n>
Tele <int> (callID) [channel_id]  tx:<tot>/<v>/<fax>ms <codec> noise:<l>  acom:<l> i/o:<l>/<l> dBm
  MODEMRELAY  info:<rcvd>/<sent>/<resent> xid:<rcvd>/<sent>  total:<rcvd>/<sent>/<drops>
         speeds(bps): local  <rx>/<tx> remote <rx>/<tx>
Proxy <ip>:<audio  udp>,<video udp>,<tcp0>,<tcp1>,<tcp2>,<tcp3>  endpt: <type>/<manf>
bw: <req>/<act> codec:  <audio>/<video>
  tx: <audio pkts>/<audio  bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120  bytes>
rx: <audio pkts>/<audio  bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120  bytes>
Telephony call-legs:  0
SIP call-legs:  2
H323 call-legs:  0
Call agent controlled call-legs:  0
SCCP call-legs:  2
Multicast call-legs:  0
Total call-legs:  4
0    : 18566 17:59:23.434 UTC Thu Feb 9  2012.1 +0 pid:0 Originate  connecting
dur 00:03:57 tx:11833/1893280  rx:11829/1892640
IP 172.19.1.254:24708 SRTP: off rtt:0ms  pl:0/0ms lost:0/0/0 delay:0/0/0ms g711alaw TextRelay:  off
media inactive detected:n media contrl  rcvd:n/a timestamp:n/a
long duration call detected:n long  duration call duration:n/a timestamp:n/a
0    : 18567 17:59:23.444 UTC Thu Feb 9  2012.1 +7720 pid:100 Answer 8182862941 active
dur 00:03:49 tx:11829/1892640  rx:11833/1893280
IP 172.19.1.254:17958 SRTP: off rtt:0ms  pl:0/0ms lost:0/0/0 delay:0/0/0ms g711alaw TextRelay:  off
0    : 18568 17:59:23.454 UTC Thu Feb 9  2012.1 +7710 pid:2050 Originate 82213404 active
dur 00:03:49 tx:11833/1893280  rx:11829/1892640
IP 201.158.135.37:47082 SRTP: off rtt:0ms  pl:0/0ms lost:0/0/0 delay:0/0/0ms g711alaw TextRelay:  off
0    : 18569 17:59:23.844 UTC Thu Feb 9  2012.1 +0 pid:0 Originate  connecting
dur 00:03:56 tx:11829/1892640  rx:11833/1893280
IP 172.31.3.3:27538 SRTP: off rtt:0ms  pl:0/0ms lost:0/0/0 delay:0/0/0ms g711alaw TextRelay:  off
SIP call-legs:  2
H323 call-legs:  0
SCCP call-legs:  2
Total call-legs:  4
CUBE_GOLD#
449
