CUCM 8.5 CUBE call drop
Hi All
i ahve CUCM 8.5 i am integrating SIP ISP through cisco CUBE , when i made the call H323-->CUBE-->SIP ISP call worked fine but i have to use fast start for inbound and outbound with MTP.
when i tried to go with  SIP trunk from CUCM to CUBE i am facing wiered situation that call completed for 6 seconds then dropped from CUCM.
i tried all possible scenario (early offer without MTP, with MTP,midcall,...etc) and same result.
in RTMT when i run the realtime monitring for CCM service i got the following error(MTPJRO is MTP Resource):
11:51:32.314 |//SIP/SIPCdpc(1,68,173)/ci=16802005/ccbId=291/scbId=0/addTransparencyInfo: Transparency info is NULL.  Not attaching anything.|1,100,50,1.294033^10.0.30.1^MTPJRO
11:51:33.165 |SDPMsg getVideoMLine - Warning video line (size=0,idx=0) not found, returning System Default |*^*^*
11:51:33.166 |SDPMsg getVideoMLine - Warning video line (size=0,idx=0) not found, returning System Default |*^*^*
11:51:33.196 |//SIP/SIPCdpc(1,68,173)/ci=16802005/ccbId=291/scbId=0/getXCiscoViPRFallbackIDAndDTMFKey: Device type 8, Pstn Fallback is not enabled|1,100,57,1.2113^10.0.30.1^*
11:51:38.173 |ViprUtils: Number has no +, not a valid E164 [9902]|1,100,62,116.1^*^*
11:51:38.173 |//SIP/SIPCdpc(1,68,173)/ci=0/ccbId=291/scbId=0/uploadVCRifRequired: VcrUploadNeeded 1|1,100,62,116.1^*^*
11:51:38.173 |MediaManager(192)::wait_AuDisconnectRequest, mCleanupPreallocatedMTP=0|1,100,62,116.1^*^*
11:51:38.174 |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=0, party 2 videocapable=0|1,100,62,116.1^*^*
11:51:41.243 |LineControl TEST DEBUGS: Number of entries in CallTable is =  1
|1,100,50,1.294041^10.0.21.21^SEP00262200FDE2
based on above how can we adjust the transparency setting other than developing script using SIP normallization.
985
