CUCM 8.5 NTP Server Issue
The Issue i am having is that my CUCM Pub. cannot communicate with our NTP server due to our NTP server requires a trusted key. Is there a way to input this key in CUCM so that it can pull the appropriate time?
Everyone's tags (2)
Hall of Fame Super Silver
What are you using as your NTP source?
Best source is a Cisco network equipment such as a router.
HTH,
Chris
It is using a router as it's NTP source, but it requires a trusted key be used and i do not know how to input the key in CUCM.
Why does it need a trusted key for NTP?
Chris
It is a security requirement for where I work. That is why it is frustrating to me, why for ntp.
can you use the below command to show the logs , please?.The below command can be done by SSH to your CUCM IP address.
utils network capture port 123
Thank you
please rate all useful information
165
