CUCM 8.5 PROBLEM WITH MOH
Dear All
We are encountering one strange issue and we need your advice
The current senario is:
All Phones register first to Subscriber CUCM.
All Phones have first TFTP the Publisher CUCM
Now the problem is:
Local calls : MOH is ok
Outgoing calls to PSTN network : MOH is ok
Incoming calls from PSTN: MOH not working..We have a DEAD air
Could you pls help??
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
  • IP Telephony
Do you have the following in your gateway?
ccm-manager music-on-hold
YES ITS THERE
Have you already checked MRGLs from GW?
All MOH servers have all MOH files?
Enabled necessary codecs unders IPVMS?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Everything was ok but for unexpecting reason the moh is not working now for incoming calls (PSTN)
Another one issue is : I tried to register one phone with the publisher CUCM.then moh is not working either for internal , external, incoming calls.....we have dead air
To which server a phone registers doesn't matter, MRGLs are what define from where they get MOH.
If you have reviewed all the config and everything seems correct, try to restart IPVMS.
java
java
sho voip rtp con while on hold.
Verify that you see the call leg indicates the gateway bound IP address and the MOH server IP address.
Is the Media bound to an interface?
Are there firewalls between gateway and MOH server?
Did the wav get loaded on all TFTP servers?
Hi to all
Finally the problem has solved
Resolution:
Reboot the Voice Gateway
Thank you for your answers
1147
