Bronze
CUCM 8.5 - simulate a failover?
We have a CM group with our Subscriber as primary and Publisher as secondary.
Is there a way to fail over a single phone without affecting the others?
I need to test a few scenarios and need to control the failover of a single phone.
Thanks!
Ven
Ven Taylor
Everyone's tags (5)
I would think of using ACLs for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Bronze
Do you mean block access from the phone to the primary server?
Ven
Ven Taylor
Just to add on to the good info from Javalenc (+5), you can simulate the FailOver for one phone only by using an extended ACL and block traffic from the sub to the ip of the phone itself.
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
319
