CUCM 8.5 trunk
Hello Fellows,
I have a CUCM 8.5 that i finished configuring, and a 2821.. I will have the 2821 router terminate all calls to a SIP trunk/provider.
So what i basically like to do is connect the CUCM-2821-SIP Provider.. My $1 question would be what's the best was to connect the CUCM 8.5 to 2821 as a H3232, SIP, or MGCP ?
I'm thinking of going the MGCP route, any sugestions fellows ?
Thx
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: CUCM 8.5 trunk
Your best bet is to use a sip trunk between your CUCM and your gateway. Configure your 2821 as a CUBE gateway. Then connect your CUBE to your service provider.
This is the best approah. Your call will be SIP-SIP all the way...
So you will have
CUCM---------sip trunk--CUBE----------(dial-peer with-sip protocol)----ITSP
NB: mgcp will not work for this scenario..So dont even thin about it
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: CUCM 8.5 trunk
So you will have
Re: CUCM 8.5 trunk
I actually thought about it (MGCP) .. Thnaks alot for your feedback!!!
Hall of Fame Super Silver
Re: CUCM 8.5 trunk
Concur, no reason to mess with multiple protocols here.
Chris
304
