CUCM 8.6.1(2) No Dependency Records Call Pickup Group
Hi there,
I'm busy with installation of CUCM 8.6.1 for one of our customers. After the installation and basic configuration, I can't see Dependency Record for Call Pickup Groups. When I want to check the Dependency Record from the Drop Down menu, it says 0 Records, but in fact there are users who are members of Pickupgroup. I have 85 pickupgroups and all of them have the same issue. When I try to check the Dependency Record of other things like Device Pools, I can see all the members.
I upgraded the CUCM from 8.6.1 to 8.6.2, but it didn't help. Anybody got any idea how I can reslove this issue.
Thanks.
1 ACCEPTED SOLUTION
Seems like a bug. I believe you are hitting this one:
CSCts02791
Dependency records for call pickup group returns no results
Symptom:
When using the dependency records for call pickup group, the result is always "
0 Record(s) are using Call Pickup Group: "
Conditions:
This is only seen as from 7.1.5.34060-1
Workaround:
Use 7.1.5.33052-2
Further Problem Description:
This issue was caused by the checkin of CSCtc66558
I believe versions 8.0 and 8.5 are affected too, but I couldn't find a fix for 8.6. Porbably
it would be better to open a TAC request and ask for a fix or ES if available.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
CSCts02791
Symptom:
Conditions:
Workaround:
Use 7.1.5.33052-2
Tere.
Super Bronze
But.. if you wantto know who's in what pickup group more than you want to spend this weekend upgrading your CUCM:
SSH to the server
Use this command:
run sql select n.dnorpattern as Ext_Number,n.fkroutepartition,pgn.dnorpattern as PG_Number ,p.name from pickupgrouplinemap pglm join numplan n on n.pkid = pglm.fknumplan_line join pickupgroup p on p.pkid = pglm.fkpickupgroup join numplan pgn on p.fknumplan_pickup = pgn.pkid
Other queries would get other dependencies if you need them...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Another thing to try is in
Another thing to try is in bulk administration > phones > generate phone report with call pickup group name.
1826
