CUCM 8.6.2 Cant view call history on certain Phones
Have 3 specific user's who cannot view any call history wha so ever, Cant find much in relation to this issue via the web, Thy are the only one's experiencing the issue on the system. I have reset the phone to no avail. also rebuilt the phone from scratch in CM. having no luck figuring it out.
any help or idea I can try
When you say "Reset" do you mean factory reset? I've experienced issues with some phones not keeping their call history after I upgraded to 8.6. To fix the issue I had to perform a factory reset of the specific phones.
Yosh
HTH Regards, Yosh
Yosh,
I did a reset from the phone configuration page, brought the phone completely down and back up.
Is there a difference between that and a "factory reset"
I even deleted the phone, end user, and rebuilt it as a new phone 7942 in this case just to start fresh
still nothing
Json,
Yes afactory reset will delete the phones firmware and all settings.  The phone will then download its firmware from CUCM and re-registers.  The process would take 10 - 15 minutes.
Factory Reset Steps:
1 - Unplug the phone.
2  - While holding down the "#" key, plug the phone back in and wait for  the phone "Line buttons" to start flashing and then dial "123456789*0#".  The phone will reload and start downloading its firmware. If the phone  doesn't start downloading its firmware, then you did it wrong and you  would need to try again.
Yosh
HTH Regards, Yosh
Thank you Yosh, was unaware of that procedure and will give it a try in hopes it resolves it. sounds like it may
I will let you know. Thanks again
- Jason
I'll wait for your response.
Yosh
HTH Regards, Yosh
Yosh,
tested it this morning, the phone will go into upgrade mode but will not download the firmware, it just keeps rebooting, any ideas? do you think another rebuild on CM will fix that?
What firmware load is on the Phone.  You made need to complete a two step firmware upgrade for the phone to upgrade.  Also, was the phone on another system before and then moved to your system.  If so you may have to remove the ITL file using the following link
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080bbcd03.shtml
Phones have been on the same system, load id
SCCP42.9-2-1S
Have you tried to remove the ITL from the phone?
How can i access
Settings > Security             Configuration
when the phone will not load? is there a different approach to this
sorry I am new to 8.6 and this has kind of been dropped in my lap with no background on the system really.
Jason,
Please verify the TFTP address on the DHCP Pool (Scope) that the phone is gettings its IP address from is pointing to a CUCM server that has the TFTP services running. If it is pointing to the correct CUCM server, please try restarting the TFTP service.
P.S.
You will not be able to get the "Settings" option of the phone at this stage.
Yosh
HTH Regards, Yosh
Hi Jason,
The phone stays in upgrading....
We need to fix this first.
Fix the issues related to DHCP & TFTP on the switch to which the phone is connected so that the phone can get the config from the DHCP server.
Sample DHCP config on switch:
ip dhcp pool dhcpconf
network A.S.D.W 255.255.255.0
default-router A.S.D.1
option 150 ip A.S.D.X ----->TFTP server of CUCM
lease infinite
ip address dhcp
Interface config:
interface FastEthernet0/1
switchport voice vlan 1
spanning-tree portfast
Check the routing issues between phone and CUCM TFTP server.
Upgrade the phone to the latest firmware and check if you have any issues.
Note: Do not disconnect the phone while the firmware is upgrading.
Tirtha
Regards, Tirtha
Jason,
Any luck with this issue?
Yosh
HTH Regards, Yosh
297
