CUCM 8.6.2 DHCP class B subnet mask problem
I have a a CUCM 8.6.2,
when i run the DHCP as a class C subnet mask everything works fine,
when i try to run the DHCP as a class B, the DHCP stop working.
for example:
Required Field
Required Field
Required Field
Required Field
once i put the subnet as 255.255.255.0 it works.
even i tried to put the subnet as 10.170.0.0 but still it didn't work with class B subnet mask
(I have a license for 1980 units)
1 REPLY
Re: CUCM 8.6.2 DHCP class B subnet mask problem
Subnet IPv4 Address: 10.170.1.0
Subnet IPv4 Address: 10.170.1.50
Primary End IPv4 Address: 10.170.1.240
IPv4 Subnet Mask: 255.255.0.0
this is in case the IP's are not visible in the above example
and of course the IP of the CUCM is in class B it is 10.170.1.10/16
211
