CUCM 8.6.2 - IP Phone 7940/7960 don´t change the time when finish DST
Hi Guys,
My Customer is having the problem about DST (date summer time) specifically about IP Phone 7940 and 7960. When finish the date summer time this model don´t change the time, only after restart logical or phisical. I simulated the problem in the CUCM with the same version 8.6.2.22900-9 and the problem too occur. I did the following procedure to try solve the problem:
1) Put the lastest version firmware about IP Phone and didn´t worked;
2) Put the lastest version dst and didn´t worked;
I search about any bug related and didn´t found nothing.
Any have idea about this?
Wilson
In your lab, did you try to use a different CUCM version, to rule out a specific release as the cause.
Yosh
HTH Regards, Yosh
Hi Yosh,
Yes, I used the release previously and the same problem ocurred.
Wilson
What timezone are you in and
What timezone are you in and what DST schedule does it follow?
Hi Brian, This is timezone
Hi Brian,
This is timezone that was more  recent when the problem occured.
admin:show timezone config
Current timezone: Brasilia Time (America/Sao_Paulo)
Timezone version: 2013d
admin:
Thank You,
Wilson
Hi Tirtha,
About the TZ update, I had already this version in my CUCM laboratory and didn´t solved.
Wilson
Hi Wilson,  We are
Hi Wilson,
  We are experiencing the same issue now, same CUCM version.
  It seems related to these two:
https://tools.cisco.com/bugsearch/bug/CSCtz20987
https://tools.cisco.com/bugsearch/bug/CSCsy25150
Eugenio
Hi Eugenio,I read the
Hi Eugenio,
I read the description about two bugs.
The first there is not fix in the same version and the workaround suggested I did, but, the Customer didn´t agree.
The second bug there is not relation about the problem. As told I did the all try to solve the problem: put the more recent version about CUCM, DST and Firmware and didn´t solved.
Wilson
247
