CUCM 8.6.2 - LowAvailableVirtualMemory
Hi Guys,
My Customer have the Cluster with 6 CUCM server and the Publisher is presenting LowAvailableVirtualMemory. I read the post below, but, Not stay clear what is the solution or if that another solution. Any have Idea about this?
admin:show status
Host Name    : spoccm01
Date         : Thu Feb 6, 2014 11:20:40
Time Zone    : Brasilia Summer Time (America/Sao_Paulo)
Locale       : en_US.UTF-8
Product Ver  : 8.6.2.22900-9
OS Ver       : 5.0.0.0-2
License MAC  : 3440B59DD214
Uptime:
11:20:41 up 151 days, 16:39,  1 user,  load average: 0.47, 0.58, 0.55
CPU Idle:   74.50%  System:   01.50%    User:   23.50%
  IOWAIT:   00.00%     IRQ:   00.00%    Soft:   00.50%   Intr/sec: 1555.45
Memory Total:        3997572K
        Free:         194632K
        Used:        3802940K
      Cached:         631508K
      Shared:              0K
     Buffers:          10316K
                        Total            Free            Used
Disk/active         25197252K       12643252K       12298008K (50%)
Disk/inactive       24797380K       12383964K       12157424K (50%)
Disk/logging        87665856K       30192512K       53020128K (64%)
admin:
admin:show memory size
Total size of memory: 4.0 GB
admin:
https://supportforums.cisco.com/thread/2174443
Wilson
  • IP Telephony
1 ACCEPTED SOLUTION
Hi Wlison,
Hope you are doing good.
Just wanted to check the status of virtual memory on the servers.
Tirtha
Regards, Tirtha
Hi Wilson,
A few things to check first.
1) Is the alert being generated at some specific time during the day or is it random? if it is at some specific times then it could be due to scheduled processes like DRS Backup , CDR Load , MWI sync etc. Any random alerts could be due to call loops , high call volume or some bug on cucm.
2) Please check the output of following for any issues on the server
show status
utils diagnose test
utils core active list
Manish
Hi Manish,
Thank You for your contact. No, the alert is permanent not is random.
Follow the outputs that You mentioned:
admin:show status
Date         : Thu Feb 6, 2014 11:59:52
OS Ver       : 5.0.0.0-2
Uptime:
11:59:53 up 151 days, 17:18,  1 user,  load average: 0.34, 0.45, 0.46
CPU Idle:   67.16%  System:   04.48%    User:   26.62%
  IOWAIT:   01.24%     IRQ:   00.00%    Soft:   00.50%   Intr/sec: 1546.00
        Free:         194612K
        Used:        3802960K
      Cached:         649620K
      Shared:              0K
     Buffers:          11052K
                        Total            Free            Used
Disk/active         25197252K       12642272K       12298988K (50%)
Disk/logging        87665856K       30202956K       53009684K (64%)
admin:
admin:utils diagnose test
Log file: platform/log/diag1.log
Starting diagnostic test(s)
test - disk_space          : Passed (available: 12346 MB, used: 12011 MB)
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : Passed
test - tomcat              : Passed
test - tomcat_deadlocks    : Passed
test - tomcat_keystore     : Passed
test - tomcat_connectors   : Passed
test - tomcat_threads      : Passed
test - tomcat_memory       : Passed
test - tomcat_sessions     : Failed - The following web applications have an unusually large number of active sessions: _root ccmcip.  Please collect all of the Tomcat logs for root cause analysis: file get activelog tomcat/logs/*
test - validate_network    : Reverse DNS lookup missmatch
test - raid                : Passed
test - system_info         : Passed (Collected system information in diagnostic log)
test - ntp_reachability    : Passed
test - ntp_clock_drift     : Passed
test - ntp_stratum         : Passed
skip - sdl_fragmentation   : This module must be run directly and off hours
skip - sdi_fragmentation   : This module must be run directly and off hours
test - ipv6_networking     : Passed
Diagnostics Completed
admin:
admin:utils core active list
      Size         Date            Core File Name
496676 KB   2013-09-07 07:40:01   core.11679.6.ccm.1378550392
admin:
Thanks again,
Wilson
Hi Wilson,
A couple of things that you can try as of now.
1) restart tomcat service on Pub
2) Fix the DNS issue as indicated in the 'utils diagnose test'
let us know if the issue persists.
Manish
Hi Manish,
About the answer 1, the restart is necessary because this message:
Failed: The following web applications have an unusually large number
of active sessions?
About the collect requested:  file get activelog tomcat/logs/* , are there any impact? Where this files are saved?
About the answer 2, is about Reverse DNS lookup missmatch? Where and verify and fix this information?
Wilson
Hi Wilson,
As Manish said we we need to restart the Tomcat and fix of DNS will help.
They are not impacting and the location is updated in the file get command.
Reverse DNS needs to fixed on the DNS servers or you might point your CUCM server to the right DNS server.
Tirtha
Regards, Tirtha
Hi Tirtha,
Thanks a lot for your contact. I agree with Manish and You that is necessary restart the Tomcat service, it can be causing the problem. About the DNS, is a problem, but, I don´t believe that there are any relationship about lowavalaiblememoryvirtual. I did the test about DNS and not was possible identify where is the problem.
10.218.60.12 Subscriber / TAUCCM01
10.221.0.12 Subscriber / CASCCM01
172.17.32.10 Publisher / SPOCCM01
172.17.32.11 Subscriber / SPOCCM02
172.17.32.12 Subscriber / SPOCCM03
172.17.32.13 Subscriber / SPOCCM04
Microsoft Windows [versão 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Todos os direitos reservados.
M:\>nslookup 172.17.32.10
Servidor:  srv10509.x.y.z.w
Address:  172.16.32.7
Nome:    spoccm01.a.b.c.d.e
Address:  172.17.32.10
M:\>nslookup 172.17.32.11
Nome:    spoccm02.a.b.c.d.e
Address:  172.17.32.11
M:\>nslookup 172.17.32.12
Nome:    spoccm03.x.y.z.w
Address:  172.17.32.12
M:\>nslookup 172.17.32.13
Nome:    spoccm04.x.y.z.w
Address:  172.17.32.13
M:\>nslookup 10.221.0.12
Nome:    casccm01.x.y.z.w
Address:  10.221.0.12
M:\>nslookup 10.218.60.12
Nome:    tauccm01.x.y.z.w
Address:  10.218.60.12
M:\>nslookup 10.218.60.13
*** srv10509.x.y.z.w não encontrou 10.218.60.13: Non-existent do
main
M:\>ping spoccm01
Disparando spoccm01.a.b.c.d.e [172.17.32.10] com 32 bytes de dados:
Resposta de 172.17.32.10: bytes=32 tempo<1ms TTL=63
Estatísticas do Ping para 172.17.32.10:
    Pacotes: Enviados = 4, Recebidos = 4, Perdidos = 0 (0% de
             perda),
Aproximar um número redondo de vezes em milissegundos:
    Mínimo = 0ms, Máximo = 0ms, Média = 0ms
M:\>
M:\>ping spoccm012
A solicitação ping não pôde encontrar o host spoccm012. Verifique o nome e tente
novamente.
M:\>ping spoccm02
Disparando spoccm02.a.b.c.d.e [172.17.32.11] com 32 bytes de dados:
Resposta de 172.17.32.11: bytes=32 tempo<1ms TTL=63
Resposta de 172.17.32.11: bytes=32 tempo=1ms TTL=63
Estatísticas do Ping para 172.17.32.11:
             perda),
    Mínimo = 0ms, Máximo = 1ms, Média = 0ms
M:\>ping spoccm03
Disparando spoccm03.x.y.z.w [172.17.32.12] com 32 bytes de dados
Resposta de 172.17.32.12: bytes=32 tempo<1ms TTL=63
Resposta de 172.17.32.12: bytes=32 tempo=4ms TTL=63
Resposta de 172.17.32.12: bytes=32 tempo=2ms TTL=63
Estatísticas do Ping para 172.17.32.12:
             perda),
    Mínimo = 0ms, Máximo = 4ms, Média = 1ms
M:\>ping spoccm04
Disparando spoccm04.x.y.z.w [172.17.32.13] com 32 bytes de dados
Resposta de 172.17.32.13: bytes=32 tempo<1ms TTL=63
Estatísticas do Ping para 172.17.32.13:
             perda),
M:\>ping tauccm01
Disparando tauccm01.x.y.z.w [10.218.60.12] com 32 bytes de dados
Resposta de 10.218.60.12: bytes=32 tempo=5ms TTL=56
Resposta de 10.218.60.12: bytes=32 tempo=6ms TTL=56
Estatísticas do Ping para 10.218.60.12:
             perda),
    Mínimo = 5ms, Máximo = 6ms, Média = 5ms
M:\>ping casccm01
Disparando casccm01.x.y.z.w [10.221.0.12] com 32 bytes de dados:
Resposta de 10.221.0.12: bytes=32 tempo=52ms TTL=56
Resposta de 10.221.0.12: bytes=32 tempo=41ms TTL=56
Resposta de 10.221.0.12: bytes=32 tempo=43ms TTL=56
Resposta de 10.221.0.12: bytes=32 tempo=44ms TTL=56
Estatísticas do Ping para 10.221.0.12:
             perda),
    Mínimo = 41ms, Máximo = 52ms, Média = 45ms
M:\>
Wilson
Hi Wilson,
The approach that we have taken here is proactive rather than re-active.
Pro-active aproach - restart suspected services looking at the symptom and configure the recommended settings.
Reactive approach - Get the output of some memory commands, get perfmon logs, look at the logs which service consuming high memory, then look at the respective service logs and ....
So here I cannot commit that Tomcat and DNS are causing the issues... but by correcting these two things we can think of anything else. Hope this helps in understanding why we are trying to fix DNS.
Now the output of lookup has to be done from CUCM servers and not from windows machine. The above output that you have shared is not going to help much to figure out DNS issue.
Let us restart the Tomcat for now and later if you see issue the issue is resolved then you are good to go
Tirtha
Regards, Tirtha
Hi Tirtha,
I used the command utils network ping and didn´t found the problem about DNS. Are there are another way to verify this?
Wilson
Hi Wilson,
These are the commands and you should be looking at external resolution not the local ones'.
DNS lookup commands
utils network host
utils network host
Tirtha
Regards, Tirtha
563
