CUCM 8.6.2 Recovery CD
Hi mates,
I got hanging process with my CUCM 8.6.2.
I made some manipulations with root passwd, then saved files end rebooted CUCM.
After that i trapped to cycling booting process with initrd (PID1).
CUCM ver. -- Bootable_UCSInstall_UCOS_8.6.2.21900-5.sgn.
Where can i get Recovery CD for ver. Bootable_UCSInstall_UCOS_8.6.2.21900-5.sgn?
Thanks in advance!
KR
Andriy
Thx Dragan,I've done it all,
Thx Dragan,
I've done it all, but the result the same.
Will do new experoments with other CUCM instance for myself, but it's a cause of making Pub backups even for lab work.
KR
Andriy
<i>I made some manipulations
That sounds ominous: With CUCM you don't have access to the root account unless you've been "clever". If you've done this, Cisco will wash their hands of you....
GTG
Please rate all helpful posts.
Hi Gordon,if u r familiar
Hi Gordon,
if u r familiar with Unix on basic level it's all possible to do with CUCM being under Linux. You can change every parameter u need.
KR
Andriy
Gordon's remark is not on the
Gordon's remark is not on the fact that you cannot do that, his remark is on the fact that the moment you do this, you lose all Cisco support. If this is only for a lab and you want to fool around and change settings, go for it.
If this is a production system, you've just lost all Cisco support on that VM.
We don't support any method for root access other than reaching Cisco TAC, and they asking you to generate the root account for logs or to fix something. Any change under root access not directed by Cisco, will also turn your system into a not supported system. Obviously, creating your own root account, and making changes on your own, has the same outcome.
Since you're on VMware workstation, I assume this is only for lab/testing, as that is also not a supported platform.
java
if this helps, please rate
www.cisco.com/go/pdi
That's clear,All is for lab
That's clear,
All is for lab env. If i needed it on prodaction mode, i would play with backup-copies only.
Thx 2 all
KR
Andriy
Just because you can doesn't
Just because you can doesn't mean you should.
I could go riding a motorbike at night, with no lights, on an icy road, with no crash helmet. Doesn't mean I should....
GTG
255
