CUCM 8.6.2 VERY STRANGE ISSUE
Hi to all
we have two CUCM 8.6.2 version
when we go to the Cisco Unified CM Group Configuration  we dont see in the field Cisco Unified Communications Manager Group Members
the two cucm
Do you have any opinion regarding this?
Regrds
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
3 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Hi Chrysostomos,
Hope all is well my friend
Can you try adding a new CCM Group and see if the Pub and Sub are available down below
to be selcted for addition to the new group?
Cheers!
Rob
Super Bronze
Is this an upgrade?
When I upgraded a customer to this version recently, all services were deactivated - this is a known bug and we simply activated the correct services again..
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Only servers running the CCM process show up in there, are you sure you have all the services running??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Chrysostomos,
Cheers!
Rob
Super Bronze
Is this an upgrade?
Aaron
Re: CUCM 8.6.2 VERY STRANGE ISSUE
Hi mate
I am very well and i hope and you
I tried but nothing show to the available list
Any ideas?
Chrysostomos
Sent from my iPhone
java
java
Hi to all
Thank you for the answers
The issue solved as:
Deactivate the services
Reboot CUCM
Activate the services
But i will give you the correct answer
Thnak you again
Rgards
274
