Community Member
CUCM - 8.6.2
Hi All - Recently we have installed CUCM - 8.6.2 with PUB and SUB, After the installltion when we checked the DB Replication in CLI where it shows 2 for both PUB and SUB.
When i check the GUI, It throws below Error.
All necessary services are UP and Running.
Connection to RTMT on cucm-sub could not be Established in PUB
Connection to RTMT on cucm-PUB could not be Established in SUB
Replication Status in PUB:
PUB - 2 GOOD
SUB - N/A
Replication Status in SUB:
SUB - 2 GOOD
PUB - N/A
Attached Screenshot for referrence.
SIVANESAN R
SIVANESAN R
CUCM - 8.6.2
Check this bug CSCua09290
try this from cli and show us the result
show perf queryclass "Number of Replicates Created and State of Replication"
Haitham
Purple
CUCM - 8.6.2
Hi Siva,
In addition to what Mr. Haitham has said, You can also run the command utils dbreplication runtimestate on both servers in a cluster to know the DB replication status.
If it shows value of 2 , then I think it could be a cosmetic problem.
regds,
aman
162
