CUCM 8.6(2a) Mobile identity and Remote destination
my question is as follow : Is it possible to have a mobile identity and a remote destination with the same Destination number ?
I want to do MVA and Extension mobility on the same mobile number but when I tried to put the same number when I create the second profile, the call manager tell me :
Error Message
Add failed. TypeDbErrors.REMOTEDESTINATION_NOT_UNIQUE
So how can I do this ? My gatewaw configuration is ok and both features works well with different destination number.
Maxime.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
No, remote destination needs to be unique.  I am confused as to what you need mobile identity since you did not mention Jabber or Mobile client.  You do not need mobile identity for EM or MVA.
HTH,
Chris
HTH,
Chris
Thank's Chris !
Maxime
541
