Community Member
CUCM 8.6 and 2811 as SIP Gateway
Hi Guys,
I have a CUCM 8.6 in virtual enviroment and an old 2811 that has CME license. I am trying to configure these from ground up as a lab for practise and etc.
I have a SIP account that I have set up on the 2811 and I can see it has registered fine, I have also set up 2 dial-peers. One for communication between the router and the CUCM and the other one is to talk to the SIP server. I assume this is how it has to be done but I may be wrong. This is my config from the router:
dial-peer voice 1 voip
description *** VOIP Trunk ***
voice-class codec 1
session protocol sipv2
session target ipv4:<sip-ip-address>
incoming called-number .
dtmf-relay sip-notify
dial-peer voice 1000 voip
destination-pattern 308618
session target ipv4:192.168.13.251
dtmf-relay sip-kpml rtp-nte
codec g711ulaw
The number that comes in is 308618 but when I ring it, I get the busy tone and I cannot see the call even being registered on the router when I do "debug ccsip all". If I do "show sip-ua reg status" it shows the sip trunk is registered and I can see on the provider's side that it's all connected.
On the Comm Manager I have added a sip trunk which points to the router which sits on 192.168.13.254 IP address abd CUCM is 13.251.
Am I missing something here? Do I need to configure something else on the router to make it work as a gateway?
Many thanks,
Dmitryc
Everyone's tags (1)
Hall of Fame Super Silver
Does outbound work?
Please post full config. But if "debug ccsip messages" does not show anything (assuming you had "term mon" on) then the issue is with either the provider not routing this call to you or perhaps your SIP trunk authentication did not work.
Chris
Community Member
Re: CUCM 8.6 and 2811 as SIP Gateway
Hi Chris,
Shows nothing but the sip-ua shows its registered.
I have attached my config. This used to be our old call manager express router so I am not sure if I should take some of the config off like the translation rules.
Thank you,
Dmitry
Can you make an outboud call?
What IOS version?
Chris
VIP Super Bronze
How are you looking for the debugs? on the console? I see that you have login to buffer enabled. You need to use "sh loggin" to see debugs logged to router buffer.
If you do this and you see the debugs, then we know the call are arriving on your gateway. You can post the debug here..
One thing you can check also is to ensure that the CSS on your sip trunk has access to the PT of the DN=308618
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
I have IOS 12.4 on here and I cannot make outbound calls. As soon as I press "9" on the phone it gives me the wrong number tone.
I have now put in "monitor console" and I can see the debugs on the screen. This is what I get
May 11 08:33:23.280: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=01525308618, Called Number=308618, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=308618
   Result=Success(0) after DP_MATCH_DEST
May 11 08:33:23.280: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1000
However the phone does not ring. I set the extension on the phone to 308618 so I do not have to do any translations.
Many thanks,
Dmitry
Community Member
in the given debug output, called number is 308618. and it is matching with dial peer 1000.
in VOIP dial peer 1000, you have configured destination pattern and incoming called number . both. in VOIP dial if you caonfigure destination pettern it will match with the calling number not called number. here the calling number will be different not 308618. so please remove the destination pattern from dial peer. so that call will match with incoming called number else configure destination pattern . and test.
Baskaran.M
Community Member
Hi Baskara,
Now that I have removed that it gives me this:
May 11 10:42:02.471: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=308618, Called Number=308618, Peer Info Type=DIALPEER_INFO_SPEECH
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
May 11 10:42:02.471: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
My config is this for the dial-peer
codec g711ulaw
Many thanks,
Dmitry
Community Member
I have upgraded to 15.1 now and I have added SIP provider's IP to the trusted ip list. This is what I get
ay 11 13:57:49.963: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 11 13:57:49.963: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=308618, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
May 11 13:57:49.963: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
May 11 13:57:49.967: //-1/2126CA488008/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=308618, Peer Info Type=DIALPEER_INFO_SPEECH
May 11 13:57:49.967: //-1/2126CA488008/DPM/dpMatchCore:
   Dial String=308618, Expanded String=308618, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
May 11 13:57:49.967: //-1/2126CA488008/DPM/dpMatchSafModulePlugin:
   dialstring=308618, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
May 11 13:57:49.967: //-1/2126CA488008/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Community Member
I seem to be getting somewhere now.
These are my dialpeers.
destination-pattern 01525308618
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 10 voip
destination-pattern 01.........
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 12 voip
translation-profile outgoing PSTN_Outgoing
preference 1
destination-pattern 011T
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
And this is what I am getting:
May 11 14:44:03.207: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=01525308617, Called Number=01525308617, Peer Info Type=DIALPEER_INFO_SPEECH
May 11 14:44:03.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=01525308617
May 11 14:44:03.211: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=01525308617, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
May 11 14:44:03.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.211: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=01525308618, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
May 11 14:44:03.215: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 11 14:44:03.215: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 11 14:44:03.215: //-1/D545C3000000/DPM/dpAssociateIncomingPeerCore:
   Calling Number=01525308618, Called Number=01525308617, Voice-Interface=0x0,
May 11 14:44:03.215: //-1/D545C3000000/DPM/dpMatchSafModulePlugin:
May 11 14:44:03.223: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=01525308617, Peer Info Type=DIALPEER_INFO_SPEECH
May 11 14:44:03.227: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 11 14:44:03.227: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=01525308617, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 11 14:44:03.227: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.227: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 11 14:44:03.227: //-1/D545C3000000/DPM/dpMatchPeersCore:
May 11 14:44:03.231: //-1/D545C3000000/DPM/dpMatchSafModulePlugin:
May 11 14:44:03.231: //-1/D545C3000000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.231: //-1/D545C3000000/DPM/dpMatchPeersCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.231: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 11 14:44:03.231: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 11 14:44:03.231: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.231: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=01525308617, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=10
May 11 14:44:03.235: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 11 14:44:03.235: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 11 14:44:03.235: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.235: //-1/D545C3000000/DPM/dpMatchPeersCore:
May 11 14:44:03.239: //-1/D545C3000000/DPM/dpMatchSafModulePlugin:
May 11 14:44:03.239: //-1/D545C3000000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
May 11 14:44:03.243: //62/D545C3000000/SIP/Error/ccsip_ipipms_peer_chnl_ind_hdlr: Peer caps is NULL
SIP: (62) Group (a= group line) attribute, level 65535 instance 1 not found.
May 11 14:44:03.283: //-1/xxxxxxxxxxxx/SIP/Error/sip_tcp_createconnfailed_to_spi: TCP create conn failed to SPI (addr:EXTERNAL-IP, port:5060)
May 11 14:44:03.283: //62/D545C3000000/SIP/Error/sipTransportPostSendFailure: Posting send failure msg
May 11 14:44:03.283: //-1/xxxxxxxxxxxx/SIP/Error/act_idle_send_msg_failure: Send Error to EXTERNAL-IP:5060 for transport TCP
May 11 14:44:03.283: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
May 11 14:44:03.283: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
May 11 14:44:03.283: //62/D545C3000000/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container
May 11 14:44:03.287: //62/D545C3000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4B9037F8
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 01525308618
Called Number            : 01525308617
Source IP Address (Sig  ): 192.168.13.254
Destn SIP Req Addr:Port  : EXTERNAL-IP:5060
Destn SIP Resp Addr:Port : EXTERNAL-IP:5060
Destination Name         : EXTERNAL-IP
May 11 14:44:03.287: //62/D545C3000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.13.254
Source IP Port    (Media): 17580
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
May 11 14:44:03.303: //61/D545C3000000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4B9091E8
Destn SIP Req Addr:Port  : 192.168.13.251:5060
Destn SIP Resp Addr:Port : 192.168.13.251:47628
Destination Name         : 192.168.13.251
May 11 14:44:03.303: //61/D545C3000000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17264
Community Member
from gateway you are sending the call directly to call manager or SIP server. if u r sending directly to CUCM remove incoming called number . and put destination pattern . and test.
now it goes to SIP server.
Community Member
SIP Provider --> 2811 Router --->> CUCM 8.6
Sorry bud, which dial-peer do I edit?
Community Member
destination-pattern .
voice-class codec 1
dtmf-relay rtp-nte
no vad
or if the calling number is 01525308618
voice-class codec 1
dtmf-relay rtp-nte
no vad
give more preference to this dial peer which points to CUCM and test and revert
Community Member
Thanks but that made no difference at all. I get the same error.
May 11 15:20:56.787: //104/BD711CDF8094/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Port    (Media): 18482
Destn  IP Address (Media): 193.203.210.38
Destn  IP Port    (Media): 57494
May 11 15:20:56.787: //104/BD711CDF8094/SIP/Call/sipSPICallInfo:
May 11 15:20:56.687: //106/BD711CDF8094/SIP/Error/sip_iwf_sip_copy_channelInfo_to_sdp: We are either escalating, orno stream found for this m-line index:1
SIP: (106) Group (a= group line) attribute, level 65535 instance 1 not found.
May 11 15:20:56.727: //-1/xxxxxxxxxxxx/SIP/Error/sip_tcp_createconnfailed_to_spi: TCP create conn failed to SPI (addr:193.203.210.38, port:5060)
May 11 15:20:56.727: //106/BD711CDF8094/SIP/Error/sipTransportPostSendFailure: Posting send failure msg
May 11 15:20:56.727: //-1/xxxxxxxxxxxx/SIP/Error/act_idle_send_msg_failure: Send Error to 193.203.210.38:5060 for transport TCP
May 11 15:20:56.727: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
May 11 15:20:56.727: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
May 11 15:20:56.727: //106/BD711CDF8094/SIP/Error/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Invalid CCB/Data/Container
May 11 15:20:56.731: //106/BD711CDF8094/SIP/Call/sipSPICallInfo:
Community Member
shut the dial peer 10 and check
4684
