CUCM 8.6 and time scheduled partitions
I have configured 2 partitions in CUCM and applied these to a hunt pilot. One for open hours and one for closed hours. Conveniently, the company was 7 days a week open the same 9-5 hours.
All works fine, until the company changed their closed hours on a couple days per week. I modified the time periods and created new ones to allow two days per week to close a little later.
Do we need to reset the partitions for the new time schedules to take affect? Because the issue I am facing is that the "Closed" schedule is coming into play  at the normal time of 5pm when it should not. I have verified that CUCM has the correct time and date, and there are now no overlapping time periods.
Everyone's tags (5)
Hello tonypearce1,
Usually, you do not need to re-set partitions when you map time schduales with it. I have a question:
did you choose "orginating device time" ? or specific time zone for time periods and time-schduales ?
Hisham
Hall of Fame Super Silver
Can you please provide more details on your configuration, i.e. list the timer schedules/time periods/assigned partitions and CSSes and the hunt pilot configuration?
Chris
285
