CUCM 8.6 Bulk Export Data - Directory Numbers
Hi there,
A client wants to implement Extension Mobility, in order to block access to certain destinations and unlock via PIN, and is using the Line CSS to implement restrictions on the calls destinations. I wanted to export all the line configurations of the directory numbers, in order to collect that info, since the client doesn't have any updated information. Ibelieve i've done it before, in CUCM 7.1 perhaps, but can't seem to find how to do it in CUCM 8.6. I can only collect the unassign DNs.
Is there any way?
Francisco
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
What information from the line are you looking to export?  You can either do BAT phone export or phone report and specify fields you want exported or you can use dial plan report to export the extensions.
HTH,
Chris
HTH,
Chris
Hi Chris,
Thanks for the answer. I haven't noticed the Bulk - Phones - Export Phones option. That's exactly what i needed.
Thanks again.
4187
