12-18-2013 10:52 PM - edited 03-16-2019 08:56 PM
Call forwarding worked without problems, we could forward our phones to external numbers and everything was ok, when somebody called to my phone, I could got the call to my cell phone.
But now when I forward my phone to external number and try to call to my phone I get busy trigger.
We didn't change configuration or install any update.
I think its my ISP-s problem, to whom we have SIP Trunk.
I don't understand log file, so can you tell what is the problem?
Here is log:
057729XXXX is called party, cell phone number
original calling party number is 240XXXXX, but it is forwarded to 2484XXX
INVITE sip:2484XXX@ISP-IP:5060 SIP/2.0
Via: SIP/2.0/UDP MY-CUCM-IP:5060;branch=z9hG4bK1003a84126249
From: <sip:057729XXXX@MY-CUCM>;tag=4052091~294be736-ce3b-450f-a7f1-c801f3cc9a7e-27746002
To: <sip:2484XXX@ISP-IP>
Date: Wed, 18 Dec 2013 13:34:18 GMT
Call-ID: 16d82e80-2b11a45a-c43e7-84450d0a@MY-CUCM-IP
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 0383266432-0000065536-0000191815-2219117834
Session-Expires: 1800
P-Asserted-Identity: <sip:057729XXXX@MY-CUCM-IP>
Remote-Party-ID: <sip:057729XXXX@MY-CUCM-IP>;party=calling;screen=yes;privacy=off
Contact: <sip:057729XXXX@MY-CUCM-IP:5060>
Max-Forwards: 68
Content-Type: application/sdp
Content-Length: 215
v=0
o=CiscoSystemsCCM-SIP 4052091 1 IN IP4 MY-CUCM-IP
s=SIP Call
c=IN IP4 MY-CUCM-IP
t=0 0
m=audio 29790 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
|2,100,56,1.173711429^MY-CUCM-IP^MTP_3
17:34:18.526 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 2|2,100,56,1.173711429^MY-CUCM-IP^MTP_3
17:34:18.526 |EnvProcessUdpHandler::fireSignal - SEND: index = 2, handler = 0xb2d59c98|*^*^*
17:34:18.526 |EnvProcessUdpPort::fireSignal - SEND, destination = ISP-IP:5060|*^*^*
17:34:18.526 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 1172, ISP-IP:5060)|*^*^*
17:34:18.536 |EnvProcessUdpHandler::handle_input - handle = 334|*^*^*
17:34:18.536 |EnvProcessUdpHandler::handle_input Status: 0, Id: 2|*^*^*
17:34:18.536 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 358 from ISP-IP:[5060]:
[12623361,NET]
SIP/2.0 100 Trying
CSeq: 101 INVITE
From: <sip:057729XXXX@MY-CUCM-IP>;tag=4052091~294be736-ce3b-450f-a7f1-c801f3cc9a7e-27746002
To: <sip:2484XXX@ISP-IP>;tag=sip+1+b3a00013+867def6a
Server: CISCO-SBC/2.x
Content-Length: 0
|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/Info/0x0/ccsip_spi_get_msg_type returned: 2 for event 1|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/Transport/0x0/context=(nil)|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/Transport/0x0/gConnTab=0xf484290, addr=ISP-IP, port=5060, connid=2, transport=UDP|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/Info/0x0/Return existing connection for port 5060 connId 2|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/Info/0x0/Checking Invite Dialog|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/Info/0xb1b50c90/INVITE response with no RSEQ - disable IS_REL1XX|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_TRYING value=500 retries=3|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/Stack/States/0xb1b50c90/0xb1b50c90 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_EXPIRES value=180000 retries=0|2,100,230,1.4901096^ISP-IP^*
17:34:18.536 |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: type=SIP_TIMER_EXPIRES value=180000 retries=0|2,100,230,1.4901096^ISP-IP^*
17:34:18.561 |EnvProcessUdpHandler::handle_input - handle = 334|*^*^*
17:34:18.561 |EnvProcessUdpHandler::handle_input Status: 0, Id: 2|*^*^*
17:34:18.561 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 396 from ISP-IP:[5060]:
[12623362,NET]
SIP/2.0 403 Forbidden
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:ISP-IP:5060>
[12623363,NET]
ACK sip:2484XXX@ISP-IP:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
INVITE sip:2484XXX@ISP's-Other-IP:5062 SIP/2.0
Via: SIP/2.0/UDP MY-CUCM-IP:5062;branch=z9hG4bK1003a95b8f3900
From: <sip:057729XXXX@MY-CUCM-IP>;tag=4052092~294be736-ce3b-450f-a7f1-c801f3cc9a7e-27746002
To: <sip:2484XXX@ISP's-Other-IP>
Call-ID: 16d82e80-2b11a45a-c43e8-84450d0a@MY-CUCM-IP
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 0383266432-0000065536-0000191816-2219117834
Contact: <sip:057729XXXX@MY-CUCM-IP:5062>
Max-Forwards: 68
Content-Length: 215
v=0
o=CiscoSystemsCCM-SIP 4052092 1 IN IP4 MY-CUCM-IP
s=SIP Call
c=IN IP4 MY-CUCM-IP
t=0 0
m=audio 29792 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
|2,100,56,1.173711431^MY-CUCM-IP^MTP_3
17:34:18.567 |EnvProcessUdpPort - EnvProcessUdpHandler::fireSignal() varId = 0|2,100,56,1.173711431^MY-CUCM-IP^MTP_3
17:34:18.567 |EnvProcessUdpHandler::fireSignal - SEND: index = 0, handler = 0xa6b4d7c0|*^*^*
17:34:18.567 |EnvProcessUdpPort::fireSignal - SEND, destination = ISP's-Other-IP:5062|*^*^*
17:34:18.567 |EnvProcessUdpPort - EnvProcessUdpHandler::send(buff, 1177, ISP's-Other-IP:5062)|*^*^*
17:34:18.569 |EnvProcessUdpHandler::handle_input - handle = 335|*^*^*
17:34:18.569 |EnvProcessUdpHandler::handle_input Status: 0, Id: 0|*^*^*
17:34:18.569 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 394 from ISP's-Other-IP:[5062]:
[12623365,NET]
SIP/2.0 100 trying -- your call is important to us
Via: SIP/2.0/UDP MY-CUCM-IP:5062;branch=z9hG4bK1003a95b8f3900;rport=5062
CSeq: 101 INVITE
Server: kamailio (3.3.1 (x86_64/linux))
Content-Length: 0
17:34:18.587 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 375 from ISP's-Other-IP:[5062]:
[12623366,NET]
To: <sip:2484XXX@ISP's-Other-IP>;tag=dc6a4ae7
CSeq: 101 INVITE
Reason: Q.850;cause=0;text="unknown"
Content-Length: 0
|2,100,230,1.4901099^ISP's-Other-IP^*
[12623367,NET]
ACK sip:2484XXX@ISP's-Other-IP:5062 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
12-18-2013 11:10 PM
SIP/2.0 403 Forbidden error
If your router is sending a SIP/2.0 403 Forbidden error to the SIP server you are registered to, there is a good chance your router is blocking the incoming call due to the toll-faud prevention feature that was added to IOS version 15.1(2)T.
If the TOLLFRAUD_APP is rejecting the call, it generates a Q.850 disconnect cause value of 21, which represents ‘Call Rejected’. The debug voip ccapi inout command can be run to identify the cause value.
Additionally, voice iec syslog can be enabled to further verify if the call failure is a result of the toll-fraud prevention. This configuration, which is often handy to troubleshoot the origin of failure from a gateway perspective, will print out that the call is being rejected due to toll call fraud. The CCAPI and Voice IEC output is demonstrated in this debug output:
%VOICE_IEC-3-GW: Application Framework Core: Internal Error (Toll fraud call rejected): IEC=1.1.228.3.31.0 on callID 3 GUID=F146D6B0539C11DF800CA596C4C2D7EF 000183: *Apr 30 14:38:57.251: //3/F146D6B0800C/CCAPI/ccCallSetContext: Context=0x49EC9978 000184: *Apr 30 14:38:57.251: //3/F146D6B0800C/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 3 with tag 1002 to app "_ManagedAppProcess_TOLLFRAUD_APP" 000185: *Apr 30 14:38:57.251: //3/F146D6B0800C/CCAPI/ccCallDisconnect: Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
The Q.850 disconnect value that is returned for blocked calls can also be changed from the default of 21 with this command:
voice service voip ip address trusted call-block cause
Source IP Address Trust List
There are three ways to return to the previous behavior of voice gateways before this trusted address toll-fraud prevention feature was implemented. All of these configurations require that you are already running 15.1(2)T in order for you to make the configuration change.
Explicitly enable those source IP addresses from which you would like to add to the trusted list for legitimate VoIP calls. Up to 100 entries can be defined. This below configuration accepts calls from those host 203.0.113.100/32, as well as from the network 192.0.2.0/24. Call setups from all other hosts are rejected. This is the recommended method from a voice security perspective.
voice service voip ip address trusted list ipv4 203.0.113.100 255.255.255.255 ipv4 192.0.2.0 255.255.255.0
Configure the router to accept incoming call setups from all source IP addresses.
voice service voip ip address trusted list ipv4 0.0.0.0 0.0.0.0
Disable the toll-fraud prevention application completely.
voice service voip no ip address trusted authenticate
Two-Stage Dialing
If two-stage dialing is required, the following can be configured to return behavior to match previous releases.
For inbound ISDN calls:
voice service pots no direct-inward-dial isdn
For inbound FXO calls:
voice-portsecondary dialtone
12-18-2013 11:18 PM
Thanks for reply
We use only CUCM, we have no VoIP gateway. We have sip trunk to provider.
So ISP's router is blocking incoming calls right?
12-18-2013 11:19 PM
Are you sure that your ISP will allow you to send a calling party number that is not provisioned in your DID range? I have seend the forbidden message when a call is sent to ITSP and the calling party number is not on the allow/white list.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
12-18-2013 11:21 PM
It is the ISP way of preventing toll-fraud as well. Check with your ISP.
