it
CUCM 8.6 console session time out
How do I prevent call manager (8.6) to log me out every 5 minutes?
Is there way to change the default session time length?
Thanks!
Everyone's tags (5)
Hall of Fame Super Silver
Here is the link to the actaul command:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html#wp313461
HTH, please rate all useful posts!
Chris
Thanks Chris,
Thanks Chris,
This command is not working for CUCM 8.0.3, is this normal?.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html#pgfId-284171
set cli session timeout
This command sets the time, in minutes, after which an active CLI session times out and disconnects.
Be aware that the new session timeout value becomes effective immediately for a new CLI session; however, active sessions retain their original timeout value. Also the show cli session timeout command reflects the new value, even if the current session does not use that value.
Note This setting gets preserved through a software upgrade and does not get reset to the default value.
Command syntax
set cli session timeout minutes
Parameters
  • minutes specifies the time, in minutes, that can elapse before an active CLI session times out and disconnects.
Value range: 5-99999 minutes
Default value: 30 minutes
Requirements
Command privilege level: 1
Allowed during upgrade: No
If you mean you cannot find
If you mean you cannot find it, most likely because it's not implemented in that version.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/8_6_1/delta/delta.html#wp1911609
java
if this helps, please rate
www.cisco.com/go/pdi
2606
