CUCM 8.6 Diversion Header modify
Hello Sirs,
To send redirecting number through a SIP trunk in CUCM 8.6, I have used the following options in the CUCM trunk:
And I have create a translation-pattern XXXX in Partition_B that prepend YYYYY to the number as I need, but the trunk stills sends XXXX instead of YYYYYXXXX.
Any help, please
1 ACCEPTED SOLUTION
VIP Super Bronze
You need to create a Called Party Transformation Pattern. This is not the same as a Translation Pattern and has a separate menu option farther down the Call Routing menu.
Please remember to rate helpful responses and identify helpful or correct answers.
VIP Super Bronze
VIP Super Bronze
Re: CUCM 8.6 Diversion Header modify
You can also use sip profiles to modify diversion header over a sip trunk (if you are using a CUBE). It is actually much better to do this with sip profiles..
e.g
This profile modifies any number from any cucm with a deiversion header to 4480000248000@the ip address of the cube.
request INVITE sip-header Diversion modify "<.> "<448000248000>
Attached is a document explaining sip profile normalization on the CUBE
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
7733
