03-15-2012 03:02 PM - edited 03-16-2019 10:09 AM
hi, we have a 4 x node cucm 8.6 cluster, that was originally installed with no domain suffix and servers defined as ip address (phones register with cucm ip, no dns). We have a requirement for users to access ccmuser page using a trusted certificate, i understand this will require all nodes to have the domain suffix set on each node when using the cli command set network domain xxxxx.xxxxxx, this command does provide a rather scary warning regards replication and certificates, i was wondering if anyone has ran this command recently? I just want confirm that this will only impact intercluster traffic and that phones will still register via cucm ip (no phone dns required).
thanks in advance
03-15-2012 03:33 PM
Yes, it works fine.
Chris
03-15-2012 06:53 PM
You can certainly make this happen but I recommend that you ake a look at the following link on Security by Default in preparation: https://supportforums.cisco.com/docs/DOC-17679#Changing_Host_Names_or_Domain_Names
Hailey
Please rate helpful posts!
03-16-2012 03:34 PM
thanks guys, that document has been a great help!
