CUCM 8.6 Forward all incoming external numbers to another extenion
Hi everyone,
I want to forward all call, that comes from external to be forwarded to another directory number. Is it possible?
1 ACCEPTED SOLUTION
Re: CUCM 8.6 Forward all incoming external numbers to another ex
You can create a Translation Pattern that converts the called number into whatever extension you want. Example for 7 digit called in number below:
TP XXXXXXX
Called Party Transform Mask 1234567
Now the best way to do this would be to have a CSS with a PT, on your PRI or Trunk, that cannot call the local extensions and would only match the Translation Pattern. From there the Translation Pattern would change the called number and the CSS, into a CSS that can call the local extensions. Example below:
CSS Local
PT Local
CSS GW
PT GW
Phone 1
PT Local
CSS Local
GW 1
CSS GW
TP XXXXXXX
PT GW
CSS Local
Yosh
HTH Regards, Yosh
Blue
HI
why dont you use Call forward all option in Ip phone.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak
I want that ONLY external calls to be forwarded.
Is it possible?
Blue
You can only set the CFNA and CFB for external calls.
For complicated solution you can see below link
https://supportforums.cisco.com/thread/2157894
Ronak Patel
TP XXXXXXX
CSS Local
PT Local
CSS GW
PT GW
Phone 1
PT Local
CSS Local
GW 1
CSS GW
TP XXXXXXX
PT GW
CSS Local
Yosh
HTH Regards, Yosh
It Worked! Thanks a lot
Lasha,
     You're welcome
Yosh
HTH Regards, Yosh
416
