CUCM 8.6 new features versus older versions
DanielGoQ_2
Hello everyone,
I was wondering if there is any kind of "official" document from Cisco showing the new features someone will get with CUCM 8.6 and considering we already have any of the older versions of CUCM like 4.X, 5.X, 6.X or 7.X.
Does anybody know about this?
Thanks a lot!
2 Accepted Solutions
Jaime Valencia
There used to be document with this in a very generic way (6.X-7.X-8.X) , to my surprise, the link I have is no longer working and I can no longer find that doc.
This info is always contained in the RNs, a list of new features and changes to features/parameters is always there.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Marwan ALshawi
just to add in a very high level
with the new CUCM 8.6 and later the Video capabilities have been improved alot and you can natively register many of VC end points such as C and EX series and have them talk directly to CTS telepresence end points with out any need to a Video xcoder
alos now you can get the ability to use translation pattern based on the calling number while used to be doable only via H323 GW ( i think this is since 8.5 ! )
not to mention there are more to find about it as Java recommend using the release notice of that version
hope this help
if helpful Rate
Leonardo Santana
This document helps you SRND = Solution Reference Network Design
http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns818/landing_uc_mgr.html
Regards!
Leonardo Santana
*** Rate All Helpful Responses***
Jaime Valencia
java
java
Marwan ALshawi
hope this help
if helpful Rate
