CUCM 8.6 on UCS 210 C M2
gpsriramdc
Level 4
Level 4
Hi All,
We have deployed the CUCM 8.6 in UCS 210 M2 Server.We faced the problem VM got to hung state.There is reponse when we tried to login via WEB & CLI.
We tried to restart the UCS server using Esxi console , it didn't respond.Finally we reboot the entire UCS server using CIMC & make UC service up.
Esxi - 4.1
CUCM - 8.6
UCS C210 M2
Is any one came across this kind of scneario..
Thanks in Advance.
Which BIOS version are you running and which CIMC version?
We ran into a similar problem just after going live with UCS C210 and later found out that there was a known issue with the bios version that the server shipped out with.
Possible causes:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1030265
CSCtw68712    UCS C-series bios fix for VMware esx intel interrupt remapping issue
Suggest you use the Host Upgrade Utility and move to 1.4.3k (we have 1.4.3j http://tools.cisco.com/squish/6Eb15
deployed and I believe variant k addresses some posible issues with LEDs on the front panel)
Upgrade procedure
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/sw/lomug/1.4.x/install/b_huu_1_4_3.html
HTH,
Nick
Possible causes:
Upgrade procedure
HTH,
Nick
Hi Nick,
Thanks for Indeed help....
+5 for you
