CUCM 8.6 problem to upgrade patches, firmware
Hi Guys,
I am working in my lab with CUCM 8.6 in the VMWare. In the last week I didn´t had problem to do upgrade firmware IP Phone, patches and another things. Now I am trying change Phone firmware and put the release for version CUCM 8.6 and I am receiving the following message: "
No valid upgrade options were found
I had already changed the SFTP server and didn´t solve, I restart the services in CUCM and didn´t solve, I restart CUCM and didn´t solve too.
Any have idea about this?
Wilson
Super Bronze
What files do you have on your SFTP server?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi AAron,
Thank You for your contact. The files:
- cmterm-ata187-qed.9-2-3-1.cop.sgn
- cmterm-devicepack8.6.2.21020-1.cop.sgn
Wilson
Hi Did you find the issue for
Did you find the issue for this?  I am experiencing the same on my Publisher, all other CUCMs see all the files on the SFTP directory.
What is the command to do via CLI please?
Steve
Hi Steve,  In my case the
Hi Steve,
In my case the problem was occurring why had the restriction in the network in my Customer (security issues), after solved this restriction was possible to do upgrade.
I didn´t understand you doubt about the commando to see CLI.
Wilson
Are you pointing to the right path where files are??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi Javalenc,
Yes, I am pointing to the right path where file. As told I did the procedure in last week, this procedure is normal for me.
Wilson
Hall of Fame Super Silver
What SFTP program are you using? What path are you refercing?
Are you doing this from OS page or CLI?
Chris
Hi Crhirs,
I am using the msftpsrv, the path used "\". I tryed the two ways OS and CLI. I used this program a many time and never had problem.
Wilson
Hi Javalenc and Chris,
I Putted the midia in UCS Server and tryed to upgrade and I received another error message:
"Unable to mount the local file system. This could be caused by a corrupt ISO file. For example, FTPing the ISO file to the remote server in ascii mode would cause this error.
I Verified that MD5 and extension file (cop.sgn) and its Ok
Wilson
Did you configure the VM to use the DVD drive from the UCS???
java
java
Hi Javalenc,
Yes, was configured  the VM to use the DVD drive from the UCS
Wilson
2089
