Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CUCM 8.6 Publisher recovery
I have CUCM/CUC/CUPS publisher install on one UCS box. Recently we identified the 3 HDD failed and now required RMA ALL 3 HDD.
Since we do not have any backup for all, whether possible we can recovery all pubs from subs (Subs are located at different data center) without backup files available?
Whether possible that we can upgrade current sub to become pub?
1 ACCEPTED SOLUTION
VIP Purple
Hi Fei,
What u need to do is to build the publisher first and then, u require to go to DRS of Publisher and from there, u can get the option from where to restore i.e. SUBSCRIBER
you can refer the DRS admin guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/8_6_1/drsag861.html
Restoring the First Node only (Rebuilding the Publisher Alone)
But I still suggest u open case with cisco.
regds,
aman
Open a TAC case. It *may* be possible that they can do some magic for you.
GTG
Please rate all helpful posts.
VIP Purple
Hi Fei,
You can recover data from Susbcriber in case if Publisher fails and do not have backup.
This feature was intoduced in CUCM 8.6.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_6_2/delta/delta862.html
New Feature for Restoring the Database of a Publisher Node
When using the Disaster Recovery System to restore the publisher node of a Cisco Unified
Communications Manager cluster, you can restore the publisher database using the database from one
of the subscriber nodes.
If the backup file that you select for the restore process includes a CCMDB database component, a
drop-down list box appears in the Restore wizard that allows you to choose the node from which to
restore database data. When you use this option, Cisco Unified Communications Manager restores the
publisher database from the database of the chosen subscriber node, and restores all nondatabase
components from the backup file that was selected during the restore process.
You can open the TAC case and take their help.
regds,
aman
Hi Aman
That's exciting new features for 8.6(2). But the will you be able to recovery Pub from Sub without any backup files? As we DO NOT have any backup procedure create on this instance.
As the Pub is down, i have managed to access Sub DRF to create backup device and do manual backup but failed as all option under DRF page is not responding, i cannot process further at all.
I will see if would adding backup device via CLI and do manual back from through there.
Cheers
Fei
VIP Purple
Hi Fei,
regds,
aman
Re: CUCM 8.6.2 Publisher recovery
Hi Aman
Long store short, we had successful restore CUCM Pub according to doc you provided, thx a lot.
In  terms of restore CUC and CUPS, whether same procedure apply as well?  But from the research, i could not find any valuable doc.
Fei
VIP Purple
Hi Fei,
Thanks for the rating.
Even I am also not aware whether this is possible or not.If u could open a new thread and let others see if it works.
regds,
aman
692
