CUCM 8.6 query
Rajnath Singh
I am new to this field. Want to know this:
Maximum number of servers supported by CUCM 8.6 deployment(is it 20 or 24?), maximum number of users in entire cluster in a VMware deployment using C220 M3 servers, maximum number of call processing servers that can be opertaional at a time.
Rajnath..
5 Replies 5
Hi Rajnath.
I think this post can answer your query.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
But the last reply on that thread is wrong, the SRND call processing chapter has all the answers to your questions.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Yes Java you're right! +5P
Carlo
What is a supercluster? Can a cluster really be scaled up to 100,000 end points?
Rajnath.
Hi Singh,
I think u are referring to MegaCluster.
A megacluster can also be deployed where customers simply require non-locally redundant call
processing functionality, rather than using Survivable Remote Site Telephony (SRST), to scale beyond
the maximum eight sites allowed in a standard cluster deployment and up to 16 Unified CM subscriber
nodes per megacluster. For example, consider a large hospital that has twelve locations and each location
has only 1,000 devices. This total of 12,000 devices could be accommodated within a standard cluster,
which has a maximum device capacity of 40,000 devices. However, in this case it is the need for
additional Unified CM subscribers, rather than additional device capacity, that requires a megacluster
deployment. In this example, a Unified CM subscriber node could be deployed in each location, and each
Unified CM subscriber could serve as the primary subscriber for the local endpoints and as a backup
subscriber for endpoints from another location.
you can refer SRND.
regds,
aman
