CUCM 8.6 VMWare changind gateway on sub
Hi - we have a 4 x node 8.6.1 cluster running on ESXI 4.1 on C210-M2 hardware.  We have licensed the cluster based on the new VMware licensing requirements using the new licensed MAC process:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html#wp81227
We now require to change the default gateway on one of our subscribers, I am guessing the hashed licensed MAC  is relative only to the Publisher / License Manager server, .i.e we cannot change any of the below on the Publsiher without voiding the cluster licenses:
•Time zone
•NTP server 1 (or "none")
•NIC speed (or "auto")
•Hostname
•IP Address (or "dhcp")
•IP Mask (or "dhcp")
•Gateway Address (or "dhcp")
•Primary DNS (or "dhcp")
•SMTP server (or "none")
•Certificate Information (Organization, Unit, Location, State, Country)
But we are ok to change the default gateway on our subscribers without causing any license issues?
Brian
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: CUCM 8.6 VMWare changind gateway on sub
Hi Brian,
You should be good to go here If for some strange
reason this did have some effect in the license MAC you would
still be covered;
Customer Impact from New Licensing Procedures
Cisco Unified Communications Manager on VMware on Cisco UCS B-Series Blade Servers uses a different licensing model than Cisco Unified Communications Manager on an MCS server. The MAC address of the NIC card is no longer used to associate the license to the server.
Instead, the license gets associated to a license MAC, which is a 12 digit HEX value created by hashing the following parameters that you configure on the server:
Time zone
Hostname
IP Mask (or "dhcp")
This hash of these fields is called the LICENSE MAC
Note : Once there is a change in any of the parameters that creates the License MAC, it will
give you 30 day grace period to generate a new license file for the CM based on new license
MAC.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_2/install/cmins802.html#wp584709
Cheers!
Rob
Hall of Fame Super Silver
You are correct, all CUCM licenses are only based on the Publisher Virtual MAC, so making changes on Subscribers will not affect any licensing.
HTH,
Chris
Hi Brian,
still be covered;
Time zone
Hostname
IP Mask (or "dhcp")
MAC.
Cheers!
Rob
HTH,
Chris
412
