04-11-2012 10:23 AM - edited 03-16-2019 10:35 AM
I see that the VMWare .ova templates for creating CUCM (CallManager) images do not include a USB controller.
I tried adding the basic EHCI+UHCI controller in order to mount a CUCM answer file (platformConfig.xml) from a USB key, however after adding this USB controller I get an error that "This hardware configuration is not supported" when trying to boot from a CUCM 8.6(2) installation DVD.
The installation proceeds fine if I do not add the USB controller to my virtual machine.
Is there no way to use an answer file when building a CUCM 8.6 VMWare appliance?
Thanks!
Solved! Go to Solution.
04-11-2012 10:55 AM
Yes, but it's not via USB
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html#wp279072
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-11-2012 10:55 AM
java
04-11-2012 12:27 PM
That would be correct. We don't support any USB functionality on CUCM running on a VM.
