CUCM 8.6
I see that the VMWare .ova templates for creating CUCM (CallManager) images do not include a USB controller.
I tried adding the basic EHCI+UHCI controller in order to mount a  CUCM answer file (platformConfig.xml) from a USB key, however after  adding this USB controller I get an error that "This hardware  configuration is not supported" when trying to boot from a CUCM 8.6(2)  installation DVD.
The installation proceeds fine if I do not add the USB controller to my virtual machine.
Is there no way to use an answer file when building a CUCM 8.6 VMWare appliance?
Thanks!
1 ACCEPTED SOLUTION
CUCM 8.6
Yes, but it's not via USB
utils import config
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html#wp279072
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
CUCM 8.6
utils import config
java
java
CUCM 8.6
That would be correct. We don't support any USB functionality on CUCM running on a VM.
505
