Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CUCM 8 limit calls log
Does anyone know if there is a way to change the limit of the number of calls that show up in the Missed, Recieved and Placed Calls list?   I looked in Service and Enterprise parameters but didn't see anything.   Anyone ever done this?
Glenn
1 REPLY
Re: CUCM 8 limit calls log
Hi Glenn,
The default number for calls log on a IP Phone registering to CUCM is 100, once is reached this 100 the buffer is
erased. This can not be changed because it is locally saved on the phone's memory and it's a limitation of the phone itself.
HTH,
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
169
