Community Member
CUCM 8 Questions
I am going to upgrade to CUCM 8 very soon.  I have a few questions for the community.
  • When upgrading from 6.1.2 to 8 are there any issues to look out for?  It looks like it should be no problem.
  • Does it still support the 7960G phones with SCCP?
  • It says that version 8 supports caller ID with MGCP and FXO.  What is the process of converting an H323 gateway to MGCP?
Thanks.
1 REPLY
Re: CUCM 8 Questions
AC is dropped so if you're using it plan accordingly by either also dropping it or look into the CUxAC suite that is the replacement.
Supported phones are listed here:
Table 19     Default Loads for Cisco Unified Communications Manager Release  8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp186410
This should give you the basics, make sure you have read the pre-requisites for caller ID MGCP with FXO.
Configure MGCP Gateway and FXO/FXS Ports on a   Cisco CallManager Server
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
Configuring Cisco CallManager with IOS MGCP  Gateways (Analog FXO, FXS Ports)
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a008009428e.shtml
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
412
