CUCM 8.x - Monitoring mgcp pri through RTMT
Wanted to know the best way to monitor mgcp pri lines through RTMT.  We are looking to see the state of all the lines (idle, down, in use) of all the lines.
a.k
Easiest way is to create a custom alert of the performance object 'DatalinkInService'. It is under Cisco MGCP PRI Device. You'll need to do it for each PRI.
Login to RTMT -->Call Manager --> Device Search --> search GW by IP address or Hostname --> right click on port --> Select Port/Channel Status
567
