09-16-2014 06:42 AM - edited 03-18-2019 11:24 AM
I am planning to upgrade CUCM 8.X to 10.X version in UCS C 200,my queries are before upgrading what are the pre requirements to be considered
How to migrate licenses? If i have UCSS/ESW contract what is the procedure tp migrate licenses? In case i don't have UCSS/ESW subscription?
Wether UCS 200 Server comptaible for telepresence ? I am plan to implement SX10 & D80 will it be comptaible?
09-16-2014 07:05 AM
Hi Siva,
U need to run LCU [License count utility] tool on PC from which CUCM is reachable.
the LCU file along with txt file , u need to share with licenisng team. This txt file u will get from PLM [prime license manager] afte u do scucssful migration from 8 to 10.
You can download the LCU from Cisco site.
IF u do not have UCSS/ESW contract, u need to place order for Migration licenses.
If u have contract, then , u can place order for CUCM 10 , through PUT [Product Upgrade tool]. You can also do the migration using PCD which is again orderable through PUT.
regds,
aman
09-16-2014 07:14 AM
Aman,
Thanks for the info,
To order a migration license what is the part number ?
Will this hardware is compatible for telepresence server?
We have two UCS C200 server in which Primary:- PUB,CUC,IM.
in another server i have installed UCCX,Sub
09-16-2014 07:34 AM
Hi Siva,
the main part code would be R-UCL-UCM-LIC-K9
for enhanced users , LIC-UCM-10X-ENHP-A
for BASIC, LIC-UCM-10X-BAS-A
for Essential, LIC-UCM-10X-ESS-A
for software , CUCM-VERS-10.X [restricted]
CUCM-VERS-10.XU[unrestricted] .
Please do consult Partnet for more details of Part codes and TP.
regds,
aman
09-16-2014 08:17 AM
But i can install VCS-C&E in UCS200?
09-16-2014 08:41 AM
Hi Siva,
You can check on this link for TP or u can raise your query in TP Community.
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_TelePresence_Video_Communications_Server
regds,
aman
09-16-2014 08:22 AM
One more thing to add
For customers with no active UCSS/ESW contracts, major version upgrades may be ordered either as an upgrade with UCSS (Migration to UCSS) or as an upgrade without UCSS (Standalone Upgrade).
Main Part code is R-UCL-UCM-MIG-K9 followed by user licenses like MIG-CUCM-BASIC for Basic user.
