CUCM 9.0.1 MOH Not Working
Using default MOH on the publisher setting sample audio source on Device/Line URI does not work.  Originally began by installing a new MOH Audio Source and none of the servers are registered.  Can not use Multicast and all settings are correct.  MOH still does not work between devices.
Everyone's tags (2)
Hi, can you double check your services. Is the IP Voice Media Streaming service activated nd running?
G.
Re: CUCM 9.0.1 MOH Not Working
Check the device pool of the moh sever and the phone and make sure they are using g711 , unless you specify all codec under the service parameter
191
