CUCM 9.0 Vmware NTP Issue
Hi all.
I have cucm 9.0 cluster on vmware ESXi 5.5. I have recieve NTP critical alarm, but my NTP sever is accessible.
Anyone ever had such alarm?
Thank you.
I see the same problem was during RU 8.5-8.6
https://tools.cisco.com/bugsearch/bug/CSCtl97969
But I have 9.0(1.10000.37)
Any ideas?
Hi Vassily,
Can you try the workaround listed for the following defect and see if the alerts stop
https://tools.cisco.com/bugsearch/bug/CSCtw46611/?reffering_site=dumpcr
Manish
You do know you need to move to a 9.1 release, and that ESXi 5.5 is not supported, right???
java
if this helps, please rate
