06-30-2014 12:58 PM - edited 03-18-2019 11:23 AM
i have a cucm 9.1.1.2000 i trying restart or shutdown but not allow . i have only CUCMBE6000 (1Pub)
This is the error show :
admin:utils system restart
Do you really want to restart ?
Enter (yes/no)? yes
Appliance is being Restarted ...
Failed to Restart the Appliance
Executed command unsuccessfully
The console show this error :
login as: ccmadmin
Command Line Interface is starting up, please wait ...
java.io.FileNotFoundException: /var/log/active/platform/log/cli.bin (Read-only file system)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:216)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.restoreIndex(c iscoRollingFileAppender.java:100)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.setFile(ciscoR ollingFileAppender.java:43)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.jav a:245)
at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.jav a:204)
at org.apache.log4j.xml.DOMConfigurator.setParameter(DOMConfigurator.jav a:691)
at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.ja va:265)
at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurat or.java:176)
at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfi gurator.java:191)
at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOM Configurator.java:523)
at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:4 92)
at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1001)
at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java :867)
at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java :755)
at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:8 91)
at sdMain.initialize(sdMain.java:500)
at sdMain.main(sdMain.java:667)
java.lang.NullPointerException
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.updateIndex(ci scoRollingFileAppender.java:117)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.nextFileName(c iscoRollingFileAppender.java:92)
at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.append(ciscoRo llingFileAppender.java:74)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:251)
at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders (AppenderAttachableImpl.java:66)
at org.apache.log4j.Category.callAppenders(Category.java:206)
at org.apache.log4j.Category.forcedLog(Category.java:391)
at org.apache.log4j.Category.debug(Category.java:260)
at com.cisco.iptplatform.cli.CliSettings.getInstance(CliSettings.java:11 4)
at sdMain.initialize(sdMain.java:512)
log4j:ERROR No output stream or file set for the appender named [CLI_LOG].
Welcome to the Platform Command Line Interface
VMware Installation:
2 vCPU: Intel(R) Xeon(R) CPU E5-2609 0 @ 2.40GHz
Disk 1: 80GB
4096 Mbytes RAM
WARNING:
The /common file system is mounted read only.
Please use Recovery Disk to check the file system using fsck.
admin:
seem the database problem.
appreciate your help
06-30-2014 01:44 PM
Try to run recovery tool CD to perform file system check & repair, this process might take 15-20 minutes.
Venkatesh
06-30-2014 01:53 PM
this is the option on cisco>Downloads>Products>Unified Communications>Call Control>CUCM>CUCM 9.1.1>Recovery software ?
I'm right ?
