cucm 9.1.1 i can't restaring or shutdown
i have a cucm 9.1.1.2000 i trying restart or shutdown but not allow .  i have only CUCMBE6000 (1Pub)
This is the error show :
admin:utils system restart
Do you really want to restart ?
Enter (yes/no)? yes
 Appliance is being Restarted ...
Failed to Restart the Appliance
Executed command unsuccessfully
The console show this error :
login as: ccmadmin
Command Line Interface is starting up, please wait ...
java.io.FileNotFoundException: /var/log/active/platform/log/cli.bin (Read-only file system)
        at java.io.RandomAccessFile.open(Native Method)
        at java.io.RandomAccessFile.<init>(RandomAccessFile.java:216)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.restoreIndex(c        iscoRollingFileAppender.java:100)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.setFile(ciscoR        ollingFileAppender.java:43)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.        java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces        sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.jav        a:245)
        at org.apache.log4j.config.PropertySetter.setProperty(PropertySetter.jav        a:204)
        at org.apache.log4j.xml.DOMConfigurator.setParameter(DOMConfigurator.jav        a:691)
        at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.ja        va:265)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurat        or.java:176)
        at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfi        gurator.java:191)
        at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOM        Configurator.java:523)
        at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:4        92)
        at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1001)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java        :867)
        at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java        :755)
        at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:8        91)
        at sdMain.initialize(sdMain.java:500)
        at sdMain.main(sdMain.java:667)
java.lang.NullPointerException
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.updateIndex(ci        scoRollingFileAppender.java:117)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.nextFileName(c        iscoRollingFileAppender.java:92)
        at com.cisco.iptplatform.fappend.ciscoRollingFileAppender.append(ciscoRo        llingFileAppender.java:74)
        at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:251)
        at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders        (AppenderAttachableImpl.java:66)
        at org.apache.log4j.Category.callAppenders(Category.java:206)
        at org.apache.log4j.Category.forcedLog(Category.java:391)
        at org.apache.log4j.Category.debug(Category.java:260)
        at com.cisco.iptplatform.cli.CliSettings.getInstance(CliSettings.java:11        4)
        at sdMain.initialize(sdMain.java:512)
log4j:ERROR No output stream or file set for the appender named [CLI_LOG].
   Welcome to the Platform Command Line Interface
VMware Installation:
        2 vCPU: Intel(R) Xeon(R) CPU E5-2609 0 @ 2.40GHz
        Disk 1: 80GB
        4096 Mbytes RAM
    WARNING:
        The /common file system is mounted read only.
        Please use Recovery Disk to check the file system using fsck.
admin:
seem the database problem.
appreciate your help
Hi, Try to run recovery tool
Try to run recovery tool CD to perform file system check & repair, this process might take 15-20 minutes.
Venkatesh
this is the option on cisco
this is the option on cisco>Downloads>Products>Unified Communications>Call Control>CUCM>CUCM 9.1.1>Recovery software ?
I'm right ?
442
