Community Member
CUCM 9.1.1 - MGCP gateway won't register to my 2811
Hello
I am trying to add a MGCP gateway on a 2811.
I have configured as per the book, but it is not registering,
here is my Router config:
2811 uptime is 2 hours, 4 minutes
System image file is "flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin"
Cisco 2811 (revision 53.50) with 509952K/14336K bytes of memory.
Processor board ID FHK1302F0YV
3 FastEthernet interfaces
24 Serial interfaces
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
2811#sh run
Building configuration...
Current configuration : 7125 bytes
version 12.4
hostname 2811
boot-start-marker
boot-end-marker
card type t1 0 2
enable secret 5 $1$ax07$1yOFpGS1rHGYm873l9n9q/
no aaa new-model
clock timezone PCLAIRE -5
clock summer-time PCLAIRE recurring
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
ip cef
no ip dhcp use vrf connected
ip domain name homelab.local
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description Home_PBX
vlan internal allocation policy ascending
interface FastEthernet0/0/0
description To Home Network$ETH-LAN$
ip address 192.168.15.50 255.255.255.0
duplex auto
speed auto
interface Serial0/2/0:23
no ip address
encapsulation ppp
isdn incoming-voice voice
control-plane
voice-port 0/2/0:23
ccm-manager mgcp
ccm-manager config server 192.168.15.11 - THIS IS THE SUBSCRIBER , SHOULD IT BE THE PUBLISHER ?
ccm-manager config
mgcp
gateway
timer receive-rtp 1200
Here is what I get:
2811(config)#do sh ccm-manager
MGCP Domain Name: 2811.homelab.local
Priority        Status                   Host
Primary         None
First Backup    None
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            09:55:04 PCLAIRE Jan 16 2014 (elapsed time: 02:00:24)
Last MGCP traffic time:         11:34:19 PCLAIRE Jan 16 2014 (elapsed time: 00:21:08)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
Backhaul/Redundant link is down
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 1
          Download Failed              : 0
        Configuration Attempted        : 0
          Configuration Successful     : 0
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command:
FAX mode: cisco
Configuration Error History:
2811(config)#
Any help greatly appreciated
John Bachman
2 ACCEPTED SOLUTIONS
VIP Super Bronze
That is because you have not configured your T1 controller for mgcp..
controller T1 0/2/0
pri-group timeslots 1-31 service mgcp
After you add this you should be able to add the bind command to the seria interface
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
controller T1 0/2/0
framing esf
linecode b8zs
you are having this config already, First shut the controller
#controller T1 0/2/0
# shut
# no pri-group timeslots 1-24
# pri-group timeslot 1-24 service mgcp
# no shut
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
VIP Super Bronze
You are missing the bind command on the serial interface..
isdn bind-l3 ccm-manager
Add this...then do no mgcp, mgcp and test again
Community Member
Thank you aokanlawon
I do not have this command, the only choice I get is q931, not ccm-manager...
2811(config)#interface Serial0/2/0:23
2811(config-if)#
2811(config-if)#isdn bind-l3 ?
  q931  Select IOS Q.931
2811(config-if)#isdn bind-l3 q931
2811(config-if)#isdn bind-l3 q931 ?
VIP Super Bronze
controller T1 0/2/0
Community Member
Re: CUCM 9.1.1 - MGCP gateway won't register to my 2811
2811(config)#controller t1 0/2/0
2811(config-controller)#pri-group timeslots 1-23 service mgcp
Cannot overwrite no serv type with one. Unconfigure existing configuration and reconfigure
2811#
I have reloaded my router and still i see this error....
Adding one point even your config do not have mgcp command
Mgcp call agent x.x.x.x service mgcp
Community Member
Thank you, Nadeem, I will go step by step, looks like the tutorial I have is incomplete...
just made this sample config.
controller T1 0/0/2
pri-group timeslots 1-24 service mgcp
interface Serial0/0/0:23
ccm-manager config server 1.1.1.2 1.1.1.1 (frist sub and second pub ip) if you want to have redundancy.actually it depeneds which one is primary tftp and secondary one.
ccm-manager config
ccm-manager redundant-host 1.1.1.1
ccm-manager mgcp
mgcp
mgcp call-agent 1.1.1.2 service-type mgcp version 0.1
add Gateway on Call manager , make sure domain name sure be exactly the same on call manager. and do no mgcp and mgcp on gateway.
Br,
Nadeem
Community Member
Still same problem, I have erased all that related to mgcp on my router, to start from scratch
2811(config)#controller T1 0/2/0
2811(config-controller)#pri-group timeslots 1-24 service mgcp
Where is this error coming from ??
Here is what I want to try:
192.168.15.10  - pub
192.168.15.11 - sub
controller T1 0/2/0
ccm-manager config server 192.168.15.10 192.168.15.11
ccm-manager config
ccm-manager redundant-host 192.168.15.11
ccm-manager mgcp
mgcp
mgcp call-agent 192.168.15.10 service-type mgcp version 0.1
controller T1 0/2/0
framing esf
linecode b8zs
# shut
# no shut
Br,
Nadeem
Community Member
Got it registered, thanks guys, I will pursue with route groups.
Thanks a lot
460
