08-21-2013 06:00 AM - edited 03-16-2019 06:58 PM
we upgraded a Cluster from 6.1.4 to 9.1.1a.
Now I have got a strange behavior using call forward.
Situation A
Phone A CFA to phone B
Phone B CFNA to phone A
Someone calls phone A or B:
Phone B rings; CFNA timeout occurs -> Phone A rings (CFA is overridden)
Situation B
Phone B CFB to phone A
Phone B is busy; someone calls phone A or B:
CFA = call forward all
CFNA = call forward no answer
CFB = call forward busy
Especially Situation A seems strage to me.
Does anybody know a workaround for this? Maybe the "CFA Destination Override" Service Parameter?
Bernhard
Solved! Go to Solution.
08-21-2013 06:28 AM
Seems to me that in both cases the system is breaking a call routing loop as soon it is detected (call forwarded to where it comes from).. I consider that proper behavoir, for sure some may not agree.
08-21-2013 06:21 AM
That behaviour would match the behaviour I would expect if 'CFA Destination Override' was set to 'Enabled'. Is this the case on your system?
CFB would always 'override' CFNA - if the phone is busy then it cannot time out.
Aaron
08-21-2013 06:26 AM
I have tested with "CFA Destination Override" Service Parameter Disabled and Enabled.
This doesn't change anything.
Maybe you got me wrong?
CFB and CFNA override the CFA!
08-21-2013 06:28 AM
08-21-2013 06:51 AM
Hi Bernhard,
I'll just add this note to the good tips from my friends Aaron & Paolo (+5 each)
It sounds like you may be hitting this bug that first appeared in
CUCM 9.1.1;
Manage an application caused CFA loop via "Forward Maximum Hop Count"
Known Affected Releases: | (1) |
Known Fixed Releases:
(0)
Cheers!
Rob
08-21-2013 06:55 AM
This might be the issue.
I guess I will have to open a case.
Thanks!
08-22-2013 03:38 AM
Answer:
The system works as it should work.
The loop breakout was introduced in CUCM 7.0(1). Futher desciption of this 'feature' can be found in the system guide of the corresponding CUCM version.
For example page 522 of system guide for CUCM 9.1 (http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91.pdf)
