Community Member
CUCM 9.1.2 - add demo licenses to existing
Hi guys,
Does anybody know what will happen if I add demo licenses for CUCM 9.1.2 in addition to existing permanent licenses? Is it possible and working solution? The goal is to extend the number of existing licenses for short period of time until additional permanent licenses will be purchased.
Thanks!
Kind regards,
Andrew C.
Kind regards, Andrew C.
1 ACCEPTED SOLUTION
Purple
Hi Andrew,
I doubt you can do it again since you have already exceeded the 60 days period.
Try deleting them for Call manager and add them, re-synchronise , if it helps .
you can refer the link
https://supportforums.cisco.com/message/4152401#4152401
regds,
aman
Purple
Hi Andrew,
I think , there is no need of adding demo licenses.
After u are finished with permanent licenses and you add more device , it would run for 60 days .You can buy additional licenses and upload  till that time it would show as Non-Compliance in ELM.
regds,
aman
Community Member
Hi Aman,
But what if the non-compliance period is already expired? What will happen after adding the demo licenses?
Kind regards,
Andrew C.
Purple
Hi Andrew,
regds,
aman
168
