CUCM 9.1.2 Backup Failure
Hi, everybody,
I have a problem with CUCM 9.1.2 when it tries to do a backup, an error is displayed on the CUOM intitled: CISCO DRF FAILURE
and when I lookup at the 'Recommanded Task', it says:
"Verify that  /common/drf has the required permission and enough disk space for the DRF user. Check the application logs for further details".
so my question is : What and/or how can I get to the directory /common/drf  and check the permissions and the disk space for the DRF user ??
your help will be really appreciated, guys.
thanks.
Hi, You need to get the root
You need to get the root access for that.
Refer the below thread for more detail:
https://supportforums.cisco.com/discussion/11377406/cucm-513-drs-backup-failed
Venkatesh
Hi This is a well known bug :
This is a well known bug :)
Have a look at the RN and the Bug tracking tool
Nicolas
Thank you for your tip,
Thank you for your tip, venperum,
I saw that thread when I was researching on the internet.
The probleme is that I don't have only one CUCM, I have a cluster of:
 - 2 CUCMs,
 - 1 CUC,
-  CUCMIMP 9,
-  CUAC 9,
-  VM for DRS feature,
-  CUCM playing as a TFTP server
I tried to open the console of the CUCM publisher, I entered my login credentials:
user:
password:
I got this command prompt shown in the pic: CLI prompt.PNG
Linux commands doesn't apply here, the only commands that applies are listed in the pic commands on cucm cli.PNG
so, my question is how to get to the root mode shown in the thread you refered me to, and at what VM ? knowing that I logged in the DRS VM, I didn't find the directory: /common as shown below in the pic: No directory common.PNG
So, how to get into the root mode, and at what virtual machine should I log into ??
Thanks, again.
root access is ONLY granted
root access is ONLY granted by Cisco TAC, you need to open a TAC and if they determine root access is required, they'll get it for this.
java
if this helps, please rate
www.cisco.com/go/pdi
this question might be silly,
this question might be silly, but I have to ask it
how to open a TAC ??
https://supportforums.cisco.com/announcement/156201/create-service-request-csc-discussions
java
Thank you all for your help,
Thank you all for your help, really appreciate
124
