CUCM 9.1.2: Cannot call from Corporate Directory
iantra123
Level 3
Level 3
We have a CUCM 9.1.2.
The IP phone can access the Corporate Directory, We can make search usin the first and last name. But cannot call the finded user when pressing the button Dial.
And also When pressin the edit dial, it is blank.
We've tested also with a CIPC and still doesn't work.
We've make a search by Number but no result.
I send in attach the result of the search.
What should be the reason, and is there any solution?
Antra
islam.kamal
Level 10
Level 10
Try this for one of end users , go to user management - end user - select one of users - make sure from first and last name , write down the DN of this user at  "telephone number" - save. Then try to search for this user and dial using on phones which able to find names not on CIPC .
please rate all useful information
islam.kamal
Level 10
Level 10
Ayodeji Okanlawon
What type of directory integration is this? LDAP or just UDS (CUCM). WHen you do a search of the end users in cucm, do you see their details?
Please rate all useful posts
Jaime Valencia
Does your users have DNs configured in the directory??
If not, there's your problem.
java
if this helps, please rate
uses have DNs configured.
The have bee configured as primary Extension.
Cisco should develop the scrip by adding a choice between "Telephone number" and "Primary Extension", on the application service.
