Community Member
CUCM 9.1.2 - Time of Day failed on incoming blocked CLI
Hello
We have configured ToD routing for customer to divert call to external 1300188763 AH/Weekend and it appears all working fine until customer reported when call from blocked CLI, it failed. Apart from this, ToD just work as normal.
Call flow is simple
Phone --sip-- CUCM -- sip -- CUBE(Service Provider edition) --sip-- carrier
I have collected that ccm traces and indicate error 604 from CUBE-SP
00414147.001 |13:57:10.558 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.15.0.253 on port 5060 index 29
[37313,NET]
INVITE sip:1300188763@10.15.0.253:5060 SIP/2.0
Via: SIP/2.0/TCP 10.15.1.4:5060;branch=z9hG4bK15474e407315
From: "anonymous" <sip:+anonymous@10.15.1.4>;tag=17857~fd0f7a44-1bb8-44f3-acce-6a8326bce3c8-33724147
To: <sip:1300188763@10.15.0.253>
Date: Sun, 19 Oct 2014 02:57:10 GMT
Call-ID: 9d2c0c80-44312886-1522-4010f0a@10.15.1.4
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Cisco-Guid: 2636909696-0000065536-0000000038-0067178250
Session-Expires:  1800
P-Asserted-Identity: "anonymous" <sip:+anonymous@10.15.1.4>
Remote-Party-ID: "anonymous" <sip:+anonymous@10.15.1.4>;party=calling;screen=yes;privacy=off
Contact: <sip:anonymous@10.15.1.4:5060;transport=tcp>
Max-Forwards: 48
Content-Type: application/sdp
Content-Length: 336
v=0
o=CiscoSystemsCCM-SIP 17857 1 IN IP4 10.15.1.4
s=SIP Call
c=IN IP4 10.15.1.254
b=TIAS:64000
b=AS:64
t=0 0
m=audio 17744 RTP/AVP 8 18 0 101
b=AS:64
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:18 G729/8000
a=ptime:20
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
00414153.002 |13:57:10.593 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.15.0.253 on port 5060 index 29 with 417 bytes:
[37315,NET]
SIP/2.0 604 Does Not Exist Anywhere
CSeq: 101 INVITE
To: <sip:1300188763@10.15.0.253>;tag=sip+1+30c20009+1e3474d7
Via: SIP/2.0/TCP 10.15.1.4:5060;received=10.15.1.4;branch=z9hG4bK15474e407315
Content-Length: 0
Contact: <sip:10.15.0.253:5060;transport=tcp>
We have configured the ToD translation pattern to use Calling Party Transform Mask but it appears that CUCM is not using calling party transform mask in translation pattern when call from blocked CLI .
I have attached ccm trace and cube-sp debug for this call. Also the sip normalization script used for sip trunk.
calling - blocked CLI (0423348232) , called - 0280456421, time - 13:57:10
ToD translation pattern configuration
Calling Party Transformations
    Use Calling Party's External Phone Number Mask- Unchecked
    Calling Party Transform Mask: +61280456421
    Prefix Digits (Outgoing Calls):
    Calling Line ID Presentation: Default
    Calling Name Presentation: Default
    Calling Party Number Type: Cisco CallManager
    Calling Party Numbering Plan: Cisco CallManager
Called Party TransformationsDiscard
    Digits  < None >
    Called Party Transform Mask : 01300188763
    Prefix Digits (Outgoing Calls) :
    Called Party Number Type: Cisco CallManager
    Called Party Numbering Plan: Cisco CallManager
SIP trunk configuration:
PSTN Access: checked
Run On all nodes: checked
Remoted-Party-ID: checked
Asserted-Identity: checked
Asserted-Type: default
Any idea why CUCM is not using calling party transform mask in ToD translation pattern when call from blocked CLI and how to fixed it??
Fei
Everyone's tags (1)
40
