CUCM 9.1 - Adjust template for Auto-Registered phones
I'm trying to find where I can adust the auto-registration phone template.  I want to be able to set the device pool, CSS, MoH, and if possilbe services subscription.
AK
1 REPLY
There's not just one place, it's spread across device defaults, unified CM, unified CM groups.
The amount of settings you can config for auto-reg is very limited, you'll need to use BAT after registration for many of the things you want.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
92
