12-31-2013 11:48 AM - edited 03-16-2019 09:03 PM
If I try a bulk insert of remote destinations that begin with a + sign (eg +15552125555) I get the following error:
"A character to numeric conversion process failed"
If i create the remote destination manually it works fine so I know that the string can contain a + sign. and If I export the existing remote destinations the format is identical to my csv. Is there anything that needs to be done for it to correctly handle the + character?
01-06-2014 02:33 AM
please share your CSV file you having issues with.
01-06-2014 01:56 PM
