CUCM 9.1 Bulk Insert Remote Destinations with a +
If I try a bulk insert of remote destinations that begin with a + sign (eg +15552125555) I get the following error:
"A character to numeric conversion process failed"
If i create the remote destination manually it works fine so I know that the string can contain a + sign. and If I export the existing remote destinations the format is identical to my csv. Is there anything that needs to be done for it to correctly handle the + character?
  • IP Telephony
Everyone's tags (2)
please share your CSV file you having issues with.
Voice CCIE #37771
Re: CUCM 9.1 Bulk Insert Remote Destinations with a +
CSV file attached. I've removed the identifyig information but this is what i exported from the call manager. If I try to import it back in it throws that error.
362
