08-25-2013 10:09 AM - edited 03-16-2019 07:02 PM
Dears,
Solved! Go to Solution.
09-01-2013 01:29 PM
Ok, now thats a supported and valid upgrade plan.
2 don't forget to adjust the OS to RHEL 3
3 downloads at cisco.com has the file you need to use, use v 1.2
5 once finished the upgrade and partition swap, change OS to RHEL 5
6 DRS the vms you upgraded, shut them down, fresh install once again all the same VMs with same info, then DRS restore
08-25-2013 10:18 AM
I suggest you read Cisco CUCM SRND as this is nicely explained there.
There can only be 1 publisher in a cluster, so you need to determine with location is best suited for it
Number of Subs depends on your sizing which you should do for each deployment. Cisco supports 1:1 and 2:1 models, where for each call processing sub there is either one backup or for each pair of subs there is 1 backup. When splitting the cluster across the wan you need to consider where the backups will be.
Also, don't forget to ensre you have adequate bandwidth and latency to split the cluster, i.e. 80 ms delay and 1.5 mbps for each remote sub from pub for ICCS traffic, plus 1.5 mbps for db replication, so if you have 2 remote subs you would require 2*1.5mbps +1.5 mbps = 4.5mbps, again well described in SRND.
As to your last question, absolutely you can migrate, however it all depends on what version you are migrating from as to how you would tackle it.
HTH, please rate all useful posts!
Chris
08-25-2013 10:27 AM
Hi Clark,
You can deploy one Publisher along with Subscriber at Central site with one Subscriber at each remote site keeping in mind RTT delay
Secondly,for migration , u can refer to Drive to 9 link which would give detail on migration.
https://communities.cisco.com/docs/DOC-35585
regds,
aman
08-30-2013 12:35 AM
Dears,
I am very confused for the migration, some of the question in my mnd which are killing me,
Can anybody give me hints in bullets please so that atleast i should start on reading.
08-30-2013 02:47 AM
HI Clark,
You should first know the existing CUCM and unity version so that u can refer the software compaibility matrix [in case if upgrades is required] and also, hardware can be considered.
You can also refer Drive to 9 program.
https://communities.cisco.com/docs/DOC-34081
regds
aman
08-30-2013 07:35 AM
Dears Aman,
Thanks for the link, I have the below query for the document provided.
08-30-2013 07:57 AM
Hi Clark,
please refer page 13 :
regds,
aman
08-30-2013 08:17 AM
HI CLark,
Alternatively,
a.u can upgrade your existing CUCM 6.1 to 8.0(3) .take backup of 8.x
b. u can build UCS wth 8.0(3) and then, restore backup taken instep a.
c.now upgrade to desired version.
d. share your exising license file on version 6 with licensing team so that they can provide lic file for 9.x
https://communities.cisco.com/docs/DOC-30825
regds,
aman
08-30-2013 08:36 AM
A: It is supported for this particular upgrade method
A: You need to build a separate lab network, all is explained in the jump upgrade docs
A: You do not load any licenses
A: You upgrade from 6.1(x) to 9.1.(2), you transfer the DB from MCS to UCS with DRS
Review the actual procedure and then come back if you have further questions
https://communities.cisco.com/docs/DOC-35653
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-30-2013 03:36 PM
Thanks for Both of you.
After reading the links i have come to one path please confirm i am on correct path.
08-30-2013 08:26 PM
Hi Clark,
Please find the replies
regds,
aman
08-30-2013 11:27 PM
Dear Aman,
08-31-2013 04:06 AM
Hi Clark,
you can refer the link for Restricted and UNRST
https://supportforums.cisco.com/thread/2190136
After u restore backup , u would get 24 files consisting of TFTP,CCMDB,MOH,Platform and drfcomponent.xml for each server in a cluster consisting of three servers .Pub would have 9 files, SUB 1 and SUB 2 wud have 7 files each .The backup files would have name as datefolloed by time at which backup was initiated and hsotname of each server.
While restoring the backup , u would get a single tar file .
https://learningnetwork.cisco.com/docs/DOC-3182
You need to configure Disaster recovery in Call manager.Also, you need to have sftp server [freeftpd]running in backgroud on PC , to take backup and restore backups.
regds,
aman
08-31-2013 02:23 PM
Dear Aman
For example suppose any installed version how can we know it is restricted or unrestricted??? where to navigate in call manager.
Aman i am much worried about after upgrading producton CUCM server 6.1 to 8.(X) all licenses of 6.1 will be carry forwarded to 8.X , OR after rebooting to 8.X it will show me the system is running is demo verson in which my half of the phones will be unregistered and there will be a major production loss. please confirm this point as this is very important
I have to run backup on every server for example publisher and suscriber 1 and subscriber 2
As per your above reply you said 24 files total from every server,
then at the time of restoration how it can be only one sngle tar file ??? I hope you mean to say to create a single tar and upload it.
08-31-2013 06:11 PM
When you log in it will say UNRSTR, otherwise it's restricted
If you pretend to upgrade the production system and want to run the services, you need a feature sw license for 8.x
Easiest way to understand how the backup works, is to do it, you'll see for yourself first hand
Sent from Cisco Technical Support Android App
